Baseboard Heat - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-05-2012, 07:50 PM   #1
baseboard heat
baseboard heat not working in one room, try to bleed the system but nothing comes out , not air or water, any ideas.
The rest of the apartment is fine, any ideas , please.
Fabianco is offline   Reply With Quote
Old 03-05-2012, 08:36 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Zone valve stuck in closed position
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-05-2012, 08:58 PM   #3
The funny thing is , there is only one pump, one zone, one thermostat . Small 2 bedroom apartment.
Any other room is working without any problem, just that bedroom is cold.
Old 03-06-2012, 07:39 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 354
Ayuh,... Then bleed it out,... It's probably air-bound...
Old 03-06-2012, 09:40 AM   #5
Rewards Points: 1,418
You may need to add water to the system. This can be an iterative (back and forth) process, add a little water, bleed a little air, add a little water, etc.
Baseboard radiator air valves don't have room for a large pocket of air so as the system becomes nearly filled with water, it can require waiting a few hours before opening the bleed valve again.
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
heat not circulating to baseboard needhelp56 HVAC 8 02-28-2010 07:05 PM
Baseboard Heat 80% Rule Question bltglt507 Electrical 1 11-06-2009 12:17 PM
electric baseboard heat drewhart Electrical 21 11-05-2009 09:12 PM
Help with bleeding baseboard heat system robinswendy HVAC 1 12-13-2008 05:04 AM
