Barrel Mystery - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-28-2009, 02:06 PM   #1
Barrel Mystery
Recently purchased 55 gallon drum of diesel and 12 volt pump. Necessary to install and remove pump twice on each refill. Pump is cast iron and weighs about 30 lbs. Bottom of pump has 2 inch pipe thread which fits the opening on the drum. To remove or install entire pump with hose attached must be rotated. Is there a device that could be placed between the drum and the pump which could be turned independent of the pump and drum?
mightymouse is offline   Reply With Quote
Old 03-28-2009, 02:14 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
If you are buying fuel in bulk ask your supplier. I have never seen a quick attach coupling but I would think there is on for you application.
Old 03-28-2009, 08:06 PM   #3
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
A 2" X 6" nipple in the barrel and a 2" threaded union maybe?
JDC is offline   Reply With Quote
Old 03-30-2009, 02:59 AM   #4
G_P
Yep. Put a union between the barrel and pump. a short nipple out of the barrel then the union then a short nipple to the pump. just unscrew the union to remove the pump without having to turn the whole pump assembly at all.
G_P is offline   Reply With Quote
Old 03-30-2009, 11:48 PM   #5
Figured it would be something simple, just could not get the brain cells working
Old 03-31-2009, 01:03 AM   #6
Rewards Points: 562
Get a barrel with "2" bungs in it. One for the pump and one for the filling. had old 30's that had those that came with roundup in them. Would think plastic 55 's would too. One bung had 2" pipe threads and other 2 " but way coarser thread. Look for those at any ag retailer!!
4just1don is offline   Reply With Quote
Barrel for french drain? l1r Building & Construction 9 06-16-2008 01:50 PM
Drainage problem - Rain Barrel? Leah Frances Landscaping & Lawn Care 4 01-30-2008 07:20 PM
large mystery plywood panel in garage - any thoughts on this?! joeyboy General DIY Discussions 15 12-02-2007 04:01 PM
Help with Barrel Tile Toof adova Roofing/Siding 8 09-08-2007 12:12 PM
Light Switch Mystery csteinke Electrical 10 06-06-2007 02:33 PM
