Barbed Fittings Into 1-1/2 Inch Black Poly - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-15-2010, 08:17 PM   #1
Licensed Engineer
Rewards Points: 171
Barbed fittings into 1-1/2 inch Black Poly
I need to re-do two connections on my swimming pool plumbing. This will require removing two barbed fittings from 1-1/2 inch black poly tubing, shortening the tubing slightly, then inserting one new fitting and re-inserting one of the old fittings.
What is the best way to insert barbed fittings into this stiff tubing? Dish soap? Wooden block with hammer? Heat gun? All three?
Thanks,
BTW - This tubing was originally installed in 1987, making it 23 years old. Just to add another challenge.
MI-Roger is offline   Reply With Quote
Old 04-15-2010, 08:41 PM   #2
Water Treatment
Rewards Points: 848
Thanks,
Using the heat gun just enough to warm and soften the poly you should be able to have no need for any thing else, but a rubber mallet might be nice to have on the side..
I have done the heat with a propane touch before when having to do what you are doing.
Very Very Light with the heat...!!!
Akpsdvan is offline   Reply With Quote
Old 04-15-2010, 10:30 PM   #3
Remodeling Contractor
heat gun is the best approach
Old 04-16-2010, 07:44 AM   #4
Just call me Andrew
Rewards Points: 1,020
When I installed my parents' sprinkler system (1" Poly) I just used a hairdryer to heat up the end of the tubing, then pushed the fittings in quickly.
Andrew
secutanudu is offline   Reply With Quote
poly gas pipe to black pipe connection hamsam Plumbing 2 05-03-2009 10:47 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Anyone use 2" black poly pipe? hawgdawg50 Plumbing 6 10-08-2008 12:22 PM
can't get new light fixture to work carolcwilson Electrical 24 08-12-2008 01:52 PM
Repairing black poly pipe MelAuston Plumbing 4 10-31-2007 09:54 PM
