-   -   Bar Sink and Utility Sink Drain Line - T or Wye (http://www.diychatroom.com/f7/bar-sink-utility-sink-drain-line-t-wye-92121/)
mykayel 01-12-2011 08:22 PM
I'm starting my basement remodel and I am planning a on putting in a bar sink and a utility sink on the other side of the wall around the corner. I can't really find any information about where should I use a sanitary T vs. a Wye. I talked to one of the city inspectors and I'm not sure if he knew the difference,as all he kept saying is that so long as there aren't sharp tight bends then its not an issue.
Attached is is a sketch of what I think it should look like and was hoping on getting some input about where I should use a Wye vs. a Sanitary T.
1. Is a sanitary T correct for attaching to the existing 3" vent?
2. Is the wye correct for the bar sink and can it be laid over on the horizontal?
3. Is the 90* bend correct for the utility sink at the begginging of the run?
4. Are sanidarty T's correct for the vent lines for each sink?
http://i104.photobucket.com/albums/m...ing-Layout.jpg
broox 01-12-2011 08:45 PM
It looks like you have the basic concept! Whenever sewage or waste is going horizontal to horizontal or vertical to horizontal you want to use a long sweep fitting(wye, long sweep 90, etc). Whenever you go horizontal to vertical, use a san tee. The vent is just air, so I believe tees are fine!
the_man 01-12-2011 09:12 PM
not 100% sure, eplumber or someone else can chime in when necessary... but would the section between the bar sink trap and it's intended vent be considered a wet vent? if so, it would be illegal under the code i use. can't do that horizontal, only vertical.
TheEplumber 01-12-2011 09:27 PM
199 Attachment(s)
Don't know what you'd officially call it except, red tag by UPC standards.
The tees and combos are ok though. Also, both fixtures can be vented on a 1.5" vent.
mykayel 01-12-2011 09:44 PM
So are you saying that this is not ok? If so, are you saying that I need to run two seperate horizontal lines?
This vent is running to the other side of the basement (horizontally) where it will also pick up the vents for the watercloset toilet and sink... so I thought I would need 2". Or at least I would need 2" after the other vents tied in so I just figured I'd run 2" all the way.
the_man 01-12-2011 10:24 PM
you won't get red tagged for oversizing pipe. what i would do with it is take both of my traps off of the vertical pipes and lower the horizontal pipe so that its just a drain. use a combo to go from horizontal to vertical, then a san tee for your trap arm. i'm way too lazy to draw it in paint, so hopefully that makes sense :laughing:
mykayel 01-12-2011 10:25 PM
Ok, so I thought about this a little more to avoid the "wet" vent. Would this layout be better?
Also, would I need a cleanout at the end of the run? I've moved the existing 3" cleanout up. I would prefer to do that all in one as I had shown above but I cannot find such a fitting.
Thank you for your help.
http://i104.photobucket.com/albums/m...g-Layout-3.jpg
the_man 01-12-2011 10:34 PM
thats what i was picturing, :thumbsup:. i would do the same to the utility sink drain, and yes i would put in a cleanout. my codebook requires it on the upper end of a horizontal run. so basically if you run the utility sink off of the vertical, then use a combo instead of a 90 to go from horizontal to verical and put a cleanout adapter into the upper end
