Banging Pipes When Faucets Are Turned On Or Off - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2011, 10:36 AM   #1
banging pipes when faucets are turned on or off
how do you fix this
Lucie01 is offline   Reply With Quote
Old 01-19-2011, 11:06 AM   #2
Hey Lucie01,
Banging pipes is a common problem and is caused by the pressure of the water coming to your faucet. Water pipes in older houses especially arenít installed to counter this. The easiest way to fix the problem is to secure the pipes using pipe straps. Usually the pipes bang directly under the sinks because there is nothing holding them in place. If this isnít the problem please give more detail. -Gregg
gotogregg is offline   Reply With Quote
Old 01-19-2011, 12:02 PM   #3
You can purchace a cheap water psi test gauge from any local hardware store, home depot. Install the gauge to your outside hose faucet connection, turn on the water, a residential house should not exceed 75 psi, if it does then you need a PRV (pressure reducing valve) installed. The valve slows down the flow volume rate a little, and stops this as well as proper pipe strapping. The device (PRV) should be installed where the main water enters the house.
Navien Plumber is offline   Reply With Quote
Old 01-20-2011, 09:47 AM   #4
Rewards Points: 508
Something I learned on this site. Easy to try.
Go under each sink and toilet and check that on/off valve is fully open. Some claim that a partially opened valve causes the banging. I had some success. Next check valves to rear of refrig, furnace humidifier. Lastly shower/tub valves which are harder to get at. Or, start in area where most recent plumbing mods were done that were fine before.
diyorpay is offline   Reply With Quote
Pipes Banging badly since Water Company installed new pump MaureenKathleen Plumbing 1 04-09-2010 06:03 AM
Steam pipes generating banging noise Dezso3 Plumbing 7 02-20-2010 05:31 PM
Banging Pipes - How to Locate Them - Issue Is Not Water Hammer - Please help! mikey33442 Plumbing 1 11-19-2009 04:44 PM
Pipes Banging FlyerFan8810 Plumbing 5 03-29-2008 08:24 PM
banging in pipes e.lukie Plumbing 4 08-19-2007 09:40 PM
