Banging Pipes At Night? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2011, 01:19 PM   #1
Banging pipes at night?
Hi,
I recently found out (or rather was awoken by) the noise of banging pipes at night in my house. I narrowed down the problem to the actual pipe that comes into the house. When I close the main valve, the banging goes away, when I open it, Banging comes back. What can it be? The pipe is not hitting anything, it seems to be coming from inside the pipe or something. We don't have an icemaker and the toilets are not leaking. Any ideas?
robtrevino is offline   Reply With Quote
Old 01-21-2011, 02:49 PM   #2
Mad Scientist
See if shutting off the water valves at the toilets stops the banging. When I had this problem, it was caused by a toilet fill valve opening and closing rapidly. I was able to solve it by keeping the toilet shutoff valve partially closed. It's probably due to overly high water pressure, and the real fix might be installing a pressure reducing valve on the main water supply.
Not saying for sure that this is your problem, but it's easy to test.
McSteve is offline   Reply With Quote
Old 01-21-2011, 03:01 PM   #3
I'll try it.
I installed a new pressure regulating valve last year, btw.
Pipes Banging badly since Water Company installed new pump MaureenKathleen Plumbing 1 04-09-2010 06:03 AM
Steam pipes generating banging noise Dezso3 Plumbing 7 02-20-2010 05:31 PM
Banging Pipes - How to Locate Them - Issue Is Not Water Hammer - Please help! mikey33442 Plumbing 1 11-19-2009 04:44 PM
Pipes Banging FlyerFan8810 Plumbing 5 03-29-2008 08:24 PM
banging in pipes e.lukie Plumbing 4 08-19-2007 09:40 PM
