Banging In Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-15-2007, 01:28 AM   #1
Question
banging in pipes
I have a powder room toilet that bangs terribly when you flush. Personally, it sounds more like a drill than a hammer to me. If you turn the cold water tap on fairly high and then down a bit this stops it but you have to leave the tap on a trickle for a few minutes or the sound will start again as soon as you turn the cold tap off. After a few minutes, the tap can be turned fully off and there will be no noise. If the washing machine is filling, this can delay the sound from starting. There are three other toilets in the house which do not have any trouble. I have tried bleeding the system by turning on all the taps and turning off the main, but this has not helped. I have replaced two ballcock assemblies so far perhaps I need to do this one too? The system is 18 years old.
e.lukie is offline   Reply With Quote
Old 08-15-2007, 04:27 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
If this banging is being caused by loose pipes and water hammer, you either have to secure the pipe better if you can get to it, add a wter hammer arrester, or try replacing the water inlet valve with a Fluidmaster 400A float-cup type. They only cost about $5-$6 bucks at a big box, and come with easy-to-follow illustrated installation instructions.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-15-2007, 11:48 AM   #3
Rewards Points: 1,910
Doesn't sound like water hammer. The drill-like chattering sounds like a bad toilet valve to me.
Old 08-15-2007, 12:53 PM   #4
my vote is also be "bad toilet valve also"...
replace it ASAP before it is too late when all your pipes got beaten up... or hold yourself a bit longer to use the upstair toilet until you get it fix...
KUIPORNG is offline   Reply With Quote
Old 08-19-2007, 09:40 PM   #5
remodeling pro
I agree, not your classic water hammer description. I was thinking a pipe through a stud that was not secured properly and was vibrating when the water flowed. I would try to locate the area where the sound is the loudest, by dragging an ear along the wall, and facing the posibility of having to open the wall up to secure the pipe. But before this, I think a few dollars for a toilet valve is definately a worthwhile investment, and I would even try completely draining down the house piping and opening all the faucets to let some air into the pipes. Many older houses do not have the sealed chambers that are used to prevent water hammer in modern plumbing. There would simply be a tee in the line and a 12" piece of pipe with a cap. Over the years, the air that is suppossed to be in this chamber is dissolved into the water, and the cushion is lost, sometimes leading to quite strange noises.
troubleseeker is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
Water Heater 1/2 inch pipes tke402 Plumbing 7 10-04-2008 11:19 AM
Installation of new pipes on Water main... NJE Plumbing 3 02-05-2007 12:06 PM
Is it normal to see green stuff on the supply pipes KUIPORNG Plumbing 2 06-30-2006 11:21 AM
