Ball Valves: Sweat Vs Threaded - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-22-2010, 10:56 PM   #16
personally i never use sweated valves anymore.
i've done hundreds of feet of copper piping and all different fittings. have never had anything leak except for multiple ball valve sweat joints when i thought i did everything right.
i now only use threaded valves, and apply teflon and pipe dope. this also lets me get a little further away from the valve with the torch.
wombosi is offline   Reply With Quote
The Following 2 Users Say Thank You to wombosi For This Useful Post:
H. A. S. (08-23-2010), Steve_P (08-23-2010)
Old 08-24-2010, 10:29 AM   #17
Rewards Points: 77
Originally Posted by TheEplumber View Post
You can transition between different pipe materials using a threaded valve. copper on incoming side and pex on outgoing side. or galvanized to pex, etc.
Ahhhh...I see. That makes sense, I've seen that done before. Thank you!
mudpaws is offline   Reply With Quote
check out the new ball valves! wombosi Plumbing 7 02-03-2009 10:00 PM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 09:19 AM
Ball and Socket Joint Question lateralan Carpentry 9 04-25-2008 10:12 AM
solder or threaded brass valves?? fast380 Plumbing 4 01-13-2008 12:08 AM
Sweating Ball Valves 47_47 Plumbing 7 10-21-2007 09:13 PM
