Ball Valve With Waste - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-02-2009, 07:03 PM   #1
Ball valve with waste
I am installing an inground sprinkler system. I will tap into 3/4" line in the basement below grade and run copper pipe to outside and install shut-off on the brick outside. Where I branch off the 3/4" line in the house, I was hoping to install a ball shut-off with a waste valve, but I estimate the waste valve will be approximately 19 feet away and 2-3 feet below the level of the outside shut-off.
Will the waste valve work? I would assume the line will not drain as the waste valve is below the tap. Correct?
bbhmj is offline   Reply With Quote
Old 06-02-2009, 07:14 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
First on all sprinklers you need to install a anti backflow (Thats code) then the ball valve after the ball valve "T" in a boiler valve or hose bib. That way you can attach a hose and drain the line.
I think what you are asking is a stop and waste valve that is buried and when shut off it drain into the earth.
Old 06-03-2009, 06:54 AM   #3
Hi plumber101, thanks for the reply.
Perhaps I didn't describe the setup properly. Below is the proposed plumbing from the water meter (which is in the basement) outwards through the brick and to the hose bibb.
Water Meter --> 3/4" line --> Tee --> 42" 3/4 vertical copper pipe with ball valve w/waste half-way up --> 20' 3/4 copper pipe (horizontal at a slight angle downward towards the exterior) through outside wall --> 3/4 ball hose bibb.
If I shut the water off, open the hose bibb outside and open the waste valve inside, will the water in the line drain out of the hose bibb?
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
ball valve leaking bwall Plumbing 10 12-31-2012 07:25 PM
Is this gas ball valve safe? nutlog Plumbing 17 12-23-2008 01:40 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
leaking 1 1/4" Brass Ball Valve creemore Plumbing 2 03-11-2005 08:23 PM
