Ball Valve Required (versus A Gate Valve) For Hot Water Heater Installation - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-17-2013, 02:31 PM   #16
Rewards Points: 6,652
Originally Posted by clydesdale View Post
I am replacing my natural gas hot water heater and someone mentioned that my gate valve on the cold water inlet is not up to code and needs to be replaced with a ball valve. Located in NJ. Does anyone know if that is something in the code. The manufacturers instructions don't reference anything about a ball valve versus a gate valve.
It is not that it is not up to code, it is just that after a while, the rubber gaskets dry out from the water, and will not seal, or even worst, will not move. Ball valves can do the same thing if left to sit for a long period of time, without rotating the valve.
At least every six months, when you change the clocks, go through the house and rotate the valves closed & open to make sure they still work. Replace any that allow water still through, or even gas, if used for gas shutoffs.
Old 03-04-2015, 11:27 PM   #17
Rewards Points: 220
gate valve
Hi I have a gate valve in my condo and it's not working and I can't turn the water off without turning all the condo units (everyone in the building) so I have to replace with a ball valve. If I was you, I'd swap it out.
dfphoto is offline   Reply With Quote
Old 03-05-2015, 04:18 AM   #18
An old Tradesmen
Rewards Points: 7,320
Hopefully he did 2 years ago when he made this thread.
Old 03-05-2015, 09:26 AM   #19
Rewards Points: 582
when we are ask to bid a water heater or any other job....we always up grade plumbing if its needed for the purpose of a good install and future service ...most if not all the locals do the same thing because it is the proper way to do the job...no need to bring up extra cost if its already included in cost of install been working for me
The Following User Says Thank You to ben's plumbing For This Useful Post:
Ghostmaker (03-05-2015)
Old 03-05-2015, 09:57 AM   #20
Rewards Points: 1,952
Bad sales pitch I guess.
Ghostmaker is online now   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Is inlet valve required for "cold in" on water heater? joemontana16 Plumbing 8 11-29-2010 07:15 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
