Ball Valve Flow Direction - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-16-2011, 08:08 PM   #1
Dave E's Avatar
Send a message via Skype™ to Dave E
ball valve flow direction
I'm trying to find out the correct flow direction through a ball valve-type shut off valve. It's the quarter turn type for 1/2 inch copper, straight through, no drain cap. Not compression or shark-type, just plain old solder. Its a Dahl Bros product I bought at HD. The part where you slip the copper tubing into is slightly longer on one side than the other. Does it matter what direction the water flows through it?
Thanks Dave
Dave E is offline   Reply With Quote
Old 04-16-2011, 08:35 PM   #2
Unless there's a directional arrow on the body of the valve to indicate direction of flow, then no it does not matter which way the water flows.
VIPlumber is offline   Reply With Quote
Old 04-17-2011, 08:29 AM   #3
Dave E's Avatar
I thought it was a simple question but I looked everywhere before I turned to DIY. Thanks again. Dave
ball valve leaking bwall Plumbing 10 12-31-2012 07:25 PM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 10:01 PM
Ball vs. Gate Valve BigJimmy Plumbing 10 06-02-2007 06:49 AM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 10:46 PM
leaking 1 1/4" Brass Ball Valve creemore Plumbing 2 03-11-2005 08:23 PM
