Ball Valve Cracked On Sprinkler Backflow. - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-18-2012, 10:14 AM   #1
Ball valve cracked on sprinkler backflow.
My lower ball valve cracked over the winter due to freezing. Can I replace just this ball valve or are you supposed to replace the entire backflow unit? I notice they sell the units complete with the ball valves. I have cut the pipes and removed the entire backflow unit. I purchased a new ball valve through amazon and plan to try and just replace the faulty valve and re solder the connections.
jamjr74 is offline   Reply With Quote
Old 04-18-2012, 10:25 AM   #2
Rewards Points: 14,020
No picture so not sure how anyone would know what your trying to work with.
Old 04-18-2012, 10:40 AM   #3
Someone with knowledge of sprinkler systems would know. Here's a photo
Old 04-18-2012, 11:30 AM   #4
Rewards Points: 2,516
Actually called a pressure vacuum breaker....just like my setup:
Ball valve cracked on sprinkler backflow.-100_4114.jpg   Ball valve cracked on sprinkler backflow.-100_4115.jpg
hammerlane is offline   Reply With Quote
Old 04-18-2012, 11:34 AM   #5
MarginallyQualified
Rewards Points: 2,464
Those look like WATT's brand ball valves.
That secondary outlet fitting on those is NOT plain vanilla.
First step is to identify what you have... this looks like your item:
http://www.watts.com/pages/_products...ls.asp?pid=564
Once that is done it's about sourcing it.
hth
Old 04-18-2012, 11:37 AM   #6
Originally Posted by jamjr74 View Post
My lower ball valve cracked over the winter due to freezing. Can I replace just this ball valve.
Is what I circled the part you are referring to as the "lower ball valve"?
Old 04-18-2012, 01:26 PM   #7
Homerepairguy's Avatar
Rewards Points: 998
There should be a test procedure for the backflow preventer vacuum breaker unit to verify that it's still working properly. In lieu of that, I would replace the vacuum breaker unit. For me, my family's health in event of loss of water pressure from the city is worth the cost of a properly working backflow preventer.
All the best,
HRG
Homerepairguy is offline   Reply With Quote
Old 04-19-2012, 10:29 AM   #8
Yes this is what I am talking about.
ball valve leaking bwall Plumbing 10 12-31-2012 07:25 PM
Ball vs. Gate Valve BigJimmy Plumbing 10 06-02-2007 06:49 AM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 10:46 PM
leaking 1 1/4" Brass Ball Valve creemore Plumbing 2 03-11-2005 08:23 PM
