-   -   Ball valve cracked on sprinkler backflow. (http://www.diychatroom.com/f7/ball-valve-cracked-sprinkler-backflow-140650/)
jamjr74 04-18-2012 11:14 AM
My lower ball valve cracked over the winter due to freezing. Can I replace just this ball valve or are you supposed to replace the entire backflow unit? I notice they sell the units complete with the ball valves. I have cut the pipes and removed the entire backflow unit. I purchased a new ball valve through amazon and plan to try and just replace the faulty valve and re solder the connections.
joecaption 04-18-2012 11:25 AM
No picture so not sure how anyone would know what your trying to work with.
jamjr74 04-18-2012 11:40 AM
1 Attachment(s)
Someone with knowledge of sprinkler systems would know. Here's a photo
Attachment 49229
hammerlane 04-18-2012 12:30 PM
2 Attachment(s)
Actually called a pressure vacuum breaker....just like my setup:
TarheelTerp 04-18-2012 12:34 PM
Those look like WATT's brand ball valves.
That secondary outlet fitting on those is NOT plain vanilla.
First step is to identify what you have... this looks like your item:
http://www.watts.com/pages/_products...ls.asp?pid=564
Once that is done it's about sourcing it.
hth
hammerlane 04-18-2012 12:37 PM
1 Attachment(s)
Originally Posted by jamjr74 (Post 901653)
My lower ball valve cracked over the winter due to freezing. Can I replace just this ball valve.
Is what I circled the part you are referring to as the "lower ball valve"?
Homerepairguy 04-18-2012 02:26 PM
There should be a test procedure for the backflow preventer vacuum breaker unit to verify that it's still working properly. In lieu of that, I would replace the vacuum breaker unit. For me, my family's health in event of loss of water pressure from the city is worth the cost of a properly working backflow preventer.
All the best,
HRG
jamjr74 04-19-2012 11:29 AM
Yes this is what I am talking about.
