Ball Valve Arrow On Side - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-16-2008, 05:41 PM   #1
Ball Valve Arrow on side
I had new ball valves installed above my washing machine and I noticed arrows on the side of them. They are pointing up and the water flo would be coming down, is this right and if not can it cause a problem? Thank You for any help.
macado33 is offline   Reply With Quote
Old 01-16-2008, 05:51 PM   #2
Union HVAC Tech.
Arfe they the type that has drain caps on the side? If not it isn't an issue on domestic water.
bigMikeB is offline   Reply With Quote
Old 01-16-2008, 06:31 PM   #3
Send a message via AIM to Marlin
Yup, I always try and install ball valves with the solid side towards the water source. Doing it the other way won't cause any problems though.
Those little drain fittings are next to worthless, I wouldn't worry about it even if it did have one.
Marlin is offline   Reply With Quote
Old 01-17-2008, 07:18 PM   #4
Union HVAC Tech.
True it really only matters on high pressure steam, gas, or something similar. The drain fittings work fine if they are taken off when you solder. It's the same as having an 1/8" hole in the pipe when you need to drain off the water.
Old 01-17-2008, 07:20 PM   #5
They usually work fine for about five years. Try removing one from an old valve. If it doesn't snap off it's clogged.
Old 01-17-2008, 07:50 PM   #6
Union HVAC Tech.
Never had one snap off, I used to carry a tiny drill bit to clean them out to drain for soldering.
ball valve leaking bwall Plumbing 10 12-31-2012 08:25 PM
Ball Valve Trouble krgoks Plumbing 7 12-01-2007 01:29 AM
Ball vs. Gate Valve BigJimmy Plumbing 10 06-02-2007 07:49 AM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 11:46 PM
leaking 1 1/4" Brass Ball Valve creemore Plumbing 2 03-11-2005 09:23 PM
