Ball Cock Valve Adjusting Screw In Toilet Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-02-2012, 03:49 PM   #1
Rewards Points: 141
Ball cock valve adjusting screw in toilet tank
Please tell me that I'm right on this one but I don't do this for a living so I'm asking...
To lower the water level in your toilet tank, you turn the adjusting screw on top of the ball cock valve clockwise. This lowers the float (big black ball) and reduces the water level/amount in the tank.
Right?
RocketGal is offline   Reply With Quote
Old 04-02-2012, 03:56 PM   #2
DIY Enthusiast
sublime2's Avatar
Yes. You could also bend the rod the ball is connected to downward if the screw didn't get you to where you would like it to be.
sublime2 is offline   Reply With Quote
Old 04-02-2012, 04:02 PM   #3
Rewards Points: 141
1" below top of overflow tube
Thanks! It worked! Now my tank has the appropriate level of water - 1" from top of overflow tube.
I've read 2 DIY websites that say turn the screw counterclockwise to lower, and this is wrong advice.
ball valve leaking bwall Plumbing 10 12-31-2012 08:25 PM
drip drip drip from toilet tank n2learning Plumbing 8 02-27-2011 03:15 PM
Leaky Toilet Tank Valve Tuckahoe Sparkplug Plumbing 4 07-10-2010 07:21 AM
Bubbles In Toilet Tank JCNimmo Plumbing 2 01-29-2010 09:11 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
