Bad Smell From Sump Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2010, 08:27 PM   #1
bad smell from sump pump
we had water coming in our basement thru a crack in a outside wall then it started coming up thru the floor. we had the crack in the wall fixed from the outside and a sump pump installed. before the sump pump was installed we noticed a bad smell only when the water would come up thru the floor. After the sump pump was install we called our city and they came out and used a camera in the sewer lines to check for a break in the sewer line. Lucky there were not breaks, but the smell is still here sometimes stronger then others. I tryed the whole beach thing with no luck. It does smell like sewer but again there are no breaks in our line. Any help would be great!!! Thanks
susan2b is offline   Reply With Quote
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 08:46 AM
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 09:37 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
