bad smell
If its on the cold side as well as the hot then try to run a chlorine and water mix through the piping. be sure you isolate the new that you will disinfect from the older line. If its only the hot side it could be the anode rod on the water heater.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
