Old 07-10-2012, 03:44 PM   #1
Bad septic pump?
Two days ago, I noticed my breaker for the septic tank pump on my sand mound system had tripped. I reset it and went outside to see what was going on. The pump had not kicked on, and the water level was approximately 3' from the top and the entire pump was submerged. I've gone out to check it each of the last two days and the water level is always maybe 1" to 2" up or down of where it was the 1st day. I have a family of 5 so it's obvious the water is still moving into the sand mound.
My question is, would it be possible that the water is seeping into the sand mound, or is it more likely the pump intermittently kicking on intermittently when I am not watching? Also if it is seeping in, do I need to replace the pump? As stated before the level has barely changed in each of the past 3 days.
Any advice would be much appreciated!!
rayians is offline   Reply With Quote
Old 07-11-2012, 08:43 AM   #2
Bad septic pump?
What is the water level in the pump chamber supposed to be?
Or rather, is the pump supposed to pump out a measured quantity of water every day?
Can you activate the pump manually such as by pulling on a float and watching it go through a cycle?
Has the breaker tripped often?
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Help with ejector pump biggidybankston Plumbing 3 10-18-2011 02:36 PM
Power 120V Pump from a 240V circuit RoberTX Electrical 26 07-06-2011 12:43 AM
septic pump issues klyrocks Plumbing 1 10-12-2010 09:24 AM
Rain Collection System Using Collection Tanks in Multiple Locations Gheuett Landscaping & Lawn Care 10 09-15-2010 09:30 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
