Is This A Bad Plumbing Job?Will The Pipes Fail? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2009, 11:23 PM   #16
Safe, Most of the Time!!
brokenknee's Avatar
Is This a Bad Plumbing Job?Will the pipes fail?
Originally Posted by II Weeks View Post
BrokenKnee wrote:
This looks OK to you? Possible outside wall (not sure but I see plywood)? No metal plates protecting them? I run pipes, electric and even low voltage in the middle of bays whenever possible and protect them with strike plates whenever needed.
Just curious, how do you run a ten foot pipe in the middle of a two by four?
I agree there should be metal plates protecting the pipe; however how do you know he did not put them in. He may not have, but it is impossible to tell from the picture.
No, as stated earlier it is a sloppy job so it does not "look all right" but IMHO there is no reason to believe it will fail.
Yes, the mixing valve should be supported.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
New Natural Gas pipes being installed frplymstr Plumbing 12 01-05-2009 02:18 PM
Ant's through slab plumbing aace Pest Control 4 02-13-2008 04:48 PM
wire next to copper plumbing pipes abc Electrical 6 02-02-2008 12:01 PM
