Bad Pex Clamp Connection? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-05-2011, 01:53 PM   #1
Just call me Andrew
Rewards Points: 1,020
Bad pex clamp connection?
I posted this in another thread, but I am re-posting here so I don't accidentally hijack another person's question.
Quick pex question....I just did a new zone for my boiler using hePEX, and one crimp out of about 15 came out a little funny. The LED came on stating the tool was tight enough (Zurn Ratcheting Clamp tool), but with I looked at the clamp, the little ears were kind of bent to one side as opposed to pressed in from either side equally. It's been under pressure (about 20psi) unheated for 24 hours and hasn't leaked?
Is it ridiculous to leave it, or if it isnt leaking, is it ok? I assume once the water hits 180 degrees, the pressure will increase and have more chance for leaks?
Andrew
secutanudu is offline   Reply With Quote
Old 04-05-2011, 07:29 PM   #2
Owner
LateralConcepts's Avatar
1 outta 15 aint bad.
When in doubt...
How long would it take you to re-crimp it???
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 04-05-2011, 09:17 PM   #3
Ahhh, now I get it, I think. If it's just a case of one side being more crimped than the other, then just redo the other side.
However the LED thing is kinda throwing me. Never seen/heard of an LED on a crimp tool. Have you got a pic of this futuristic gadget?
VIPlumber is offline   Reply With Quote
Old 04-05-2011, 09:27 PM   #4
lowes used to sell a pinch tool with a tiny light that lit up when the handles were fully compressed, i think this is what he's talking about. i always laughed at it cause it was like 30 bucks more for the led, seemed like a waste of money. just checked their site, didn't see it listed anymore
the_man is offline   Reply With Quote
Old 04-05-2011, 10:24 PM   #5
Just call me Andrew
This is the tool I have, I got it at my local plumbing supply house:
http://www.zurnpex.com/Portals/4/ZNPA198.pdf
I'll try and post a pic of the crimp in question tomorrow. The ears are closed all the way, it's sort of slanted to one end...not a ton of work to re-do it, but it's a pain to drain the system.
Andrew
Old 04-07-2011, 11:12 AM   #6
Household Handyman
Rewards Points: 1,408
Well now, that is a cute little "Buck Rogers" type gadget.
Sump Pump: Screw Type Clamp vs. Cementing ABS henlij Plumbing 12 02-25-2011 06:29 PM
3 way switch with pass through power connection issue ccmbee Electrical 2 09-28-2010 02:38 PM
White crud on copper/brass ground clamp Ultrarunner2017 Electrical 10 03-09-2010 01:25 PM
gas dryer connection question rvegab00 Plumbing 7 12-07-2009 10:53 AM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 06:10 AM
