Bad Odor From Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-07-2009, 10:18 PM   #1
Rewards Points: 150
Bad odor from sink
Ok so I noticed a bad odor from my kitchen sink. My sink is a double stainless steel with pcv drain. Just installed about 2 months ago. I pored straight bleech in the sink and let it sit for 15 min. I just did that an hour ago. So I'm not sure if it worked. Maybe some food? But I'm used to the smell now since I been home all night. When I get home tomorrow from work I'll be able to tell. Any ideas?
fabian is offline   Reply With Quote
Old 04-07-2009, 10:54 PM   #2
Rewards Points: 1,088
Hmm, pouring straight bleach into the sink may not be a good idea since many have said that it will eat away at the PVC pipe, although the trap is easily replaced.
I heard that grinding a lemon in the garbage disposal is a good way to get rid of the smell.
handy man88 is offline   Reply With Quote
Old 04-08-2009, 05:33 AM   #3
Does the sink have a disposal - the most likely cause of odors. If yes run a lot of ice through it to break up any particles and then a lemon as recommended above. There is also a specific disposal cleaning product that is sold at lowes/HD, etc. that you run through them - does a pretty good job of clearing out the smells.
Rivethead is offline   Reply With Quote
Old 04-08-2009, 06:59 AM   #4
HVAC / Plumbing
You can take the drain apart under the sink & clean out the gunk.. It will work for a while... I have the same prob. my dishwasher is tied to sink drain.. I just use a little bleach now & then
kenmac is offline   Reply With Quote
Old 04-08-2009, 09:37 AM   #5
Rewards Points: 150
I don't have a garbage disposal. I said a double stainless steel sink with obviously 2 drains into one trap.
Old 04-08-2009, 01:50 PM   #6
Rewards Points: 156
trap not full enough?
If the trap isn't full enough, you'll get some poop gas making its way back to the drap.
jayp is offline   Reply With Quote
Old 04-08-2009, 05:09 PM   #7
Had one that was due to food trapped in the dishwasher drain line that feeds the sink drain. Had to flush it through the air break.
Old 04-08-2009, 08:47 PM   #8
HVAC / Plumbing
Soap scum , etc will collect in & on the walls of the PVC.. Take the drain apart you will see it
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 07:07 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 08:43 AM
Help with construction of laundry sink VokinLoksar Plumbing 3 07-06-2008 06:42 PM
