-   -   Bad install on hot water heater vent? (http://www.diychatroom.com/f7/bad-install-hot-water-heater-vent-178760/)
teeb57 05-04-2013 06:30 PM
Just bought a new house. Got some estimates on replacing a hot water heater. Two contractors that took a look at the heater saw that the previous owners had the heater venting out of the basement and into the ground. Neither one could believe that anyone would vent their water heater this way and were both adamant that this need to be reconfigured as it's probably releasing carbon monoxide into the house. I told this to a friend of mine who's pretty handy at fixing things around the house. His comments were that it was no big deal.
After seeing the looks on those two contractors faces and how disbelieving they both were that this exhaust ever passed inspection, I'm inclined to believe them but don't want to be gouged either.
Any thoughts?
framer52 05-04-2013 07:30 PM
a picture would help us determine this.
gregzoll 05-04-2013 08:07 PM
Majority of the areas, do not require a licensed plumber to install water heaters, nor to have a permit check after the install. Most likely original owner that installed the unit. As for the exhaust going into the ground, I am guessing from looking at this thread http://www.diychatroom.com/f47/dryer...nstall-175669/ the exhaust is also only about nine inches off the ground.
From the sounds of it, it appears that you got yourself into a pretty bad money pit. Pictures speak volumes.
jmon 05-04-2013 08:16 PM
How exactly is it "vented into the ground"? Is it power vented out the side and then angled towards the ground?
Maybe cheaper and easier to power vent out the side then to go up through the roof with all new vent pipe, if the manual and local code says you can. Without a picture it's hard to determine. The hwh manual usually tells you exactly how the water heater should be vented. Follow all local codes and manufactures instructions on venting. Or hire a local licensed pro.
Please post a picture when you can so we can give you better and more accurate advice. Thanks.
jagans 05-04-2013 08:25 PM
Yeah, something is not right here. Why would anyone vent a water heater "Into the Ground" You would have to go out of your way to do something stupid and illegal.
teeb57 05-04-2013 10:47 PM
2 Attachment(s)
Far away then a close up view. In the close up view, the two lines to the left are water lines. The PVC at the top is the sump drain and is about 6 inches above ground level when the PVC exits the house. The heater's exhaust is just below that. You can see it going into the basement wall here but it's located, best I can tell, under about 6" of concrete when it exits the house. There is no power vent.
Thank you all for your replys, Steve
TheEplumber 05-04-2013 11:02 PM
199 Attachment(s)
That is bizarre!!
Look in side the vent- what do you see?
Do you by any chance have a chimney outside?
You better get a carbon monoxide sensor installed pronto- that picture says you are flirting with DEATH
teeb57 05-04-2013 11:08 PM
Originally Posted by TheEplumber (Post 1172733)
That is bizarre!!
There is no chimney. There's nothing to take a picture of on the outside of the house because the exaust is venting into the ground. I'd have to start cracking concrete outside to be able to get to it. We were not able to look up into the chimney stack.
gregzoll 05-04-2013 11:09 PM
If I had to guess, the OP needs to go outside and take a picture, along with if there is soil and no concrete, to start digging, to see where that exhaust goes. Really need more information here.
teeb57 05-04-2013 11:50 PM
There's no soil, just concrete. And I'm not about to start busting up my drive way to find this exhaust, assuming there is one.
QueBall 05-05-2013 12:18 AM
I think the fumes are messing with your head.
Find out where the exhaust is going and turn off that heater. Who cares about concrete. Cement is cheap and easy to replace.
Remove the joint before the wall and stick an inspection camera up the pipe if you value your concrete over your life. Do not turn that heater on again until you know what is going on.
How did a professional even leave your property without checking for CO levels or inspecting the termination on that pipe?
teeb57 05-05-2013 12:37 AM
Thanks for your advice. One installer did check for CO2 and said it was reading slightly higher than normal. Both installers suggested, as you did, not to run the water heater.
Which brings me back to my original question. Is this installation acceptable? Judging from most reactions here, it's sounding very risky. And the fumes haven't got to me poor little head yet, I've just never had to deal with anything like this before. Thanks for the cam advice, that sounds like a good idea.
QueBall 05-05-2013 12:46 AM
The joints should be easy to dismantle. Likely just a screw and foil tape along with any paint we see in those photos is holding the elbow to the straight section.
You may even see enough with just a flashlight to figure out where it's going.
There are cheap inspection cameras for less that $100 you can buy if you cannot borrow or rent one.
Eg:
http://www.harborfreight.com/digital...era-67979.html
http://www.canadiantire.ca/AST/brows...ion+Camera.jsp (when on sale it's $99 or less)
QueBall 05-05-2013 12:52 AM
Not acceptable. Without a powered vent that heater must have a chimney going up up up. The rising hot gasses create the chimney effect creating an upward draft to draw up the gasses. If it's not going up then even if it goes out your wall and somehow makes it to the open air it's not going up far enough to create a chimney so any little breeze or positive pressure differential and it's like someone built a campfire in your basement.
teeb57 05-05-2013 12:54 AM
I like that. Will look to rent one Monday. Thanks!
