#1 |
backup sump pump does not clear the pit when triggered, normal?
My backup sump pump does not clear the pit when triggered, normal?
I have the sensor about 8" from the top, and when I unplug the sumppump and let it fill, they backup will trigger when the sensor is hit, but will only discharge about 10" of water, and then stop. Is that normal, or is it suppose to run enough to clear the whole pit? |
#2 |
Master General ReEngineer
Ayuh,..
Generally speaking,... The sump pump is supposed to keep the sump low enough to continue collecting water,... Not necessarily drain the sump Completely dry.... |
#3 |
Most sump pumps have a high and low sensor. They do not normally "clear" the sump of water. Since the inlet is usually on the bottom of the pump, there is a chance that it would run dry and overheat the motor.
If you have never made a mistake, you haven't done much. |
#4 | |
backup sump pump does not clear the pit when triggered, normal?Quote:
| Display Modes | |
| Sump pump pit water level --- problem | de12 | Plumbing | 49 | 02-27-2011 02:42 PM |
| Sewer gas smell in basement from sump pump | mirage212 | Plumbing | 15 | 10-23-2008 07:09 PM |
| Sump Pump Design | handy man88 | Plumbing | 2 | 10-04-2008 10:48 PM |
| sump pump continuing running | deck hand | Plumbing | 2 | 01-16-2008 05:35 PM |
