Backup Sump Pump & Check Valve Issues - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-18-2012, 07:12 PM   #1
Rewards Points: 462
Backup sump pump & check valve issues
Hey all,
I recently bought and installed a Liberty 441 battery back up sump pump. I had tested it previously by filling the sump pit with a bucket of water and it did the trick. Today was our first decent rain and the sump pump was running every few minutes so I decided to give it a true test run.
I unplugged the AC pump and the backup kicked in, but it would not pump any water. As soon as I plugged in the AC pump it ran and emptied the pit. I unplugged it again and let the backup kick in. No luck. I disconnected and emptied the discharge pipe above the check valve, turned on the 441 and it pumped the water. I let it refill a couple more times and it pumped out the water quickly. Problem solved? No. I plugged the AC pump back in and let it run to empty the pit and then unplugged it to let the 441 run. Again it would not pump.
So here's my guess as to what is happening. Tell me if you think I'm right. The 441 has a smaller diameter discharge so I'm under the assumption that it outputs a lower volume of water than the AC pump. So when I start with a clear discharge pipe and only the 441 runs, there is less water weight left sitting on top of the upper check valve after each cycle. As soon as the AC pump runs, it leaves a lot more water in the pipe and the 441 isn't strong enough to break open the check valve.
Each sump pump has its own check valve down in the pit, per the manufacturer's instructions, so really, the upper check valve outside of the pit is only a backup. My next step is to try to remove it but if the weight of the water in the pipe left by the AC pump is just too much for the 441, then what?
Any opinions, suggestions?
Richo is offline   Reply With Quote
Old 06-18-2012, 08:43 PM   #2
Rewards Points: 1,514
Are you sure the backup pump is pumping nothing. Or is the check valve for the AC pump still ajar so whatever is pumped by the backup pump goes back down into the pit through the AC pump backwards?
If the backup pump is not strong enough, could you give it a separate smaller diameter outlet pipe which joins the existing outlet pipe after the latter has begun its downslope outside the foundation?
The Following User Says Thank You to AllanJ For This Useful Post:
oh'mike (05-01-2015)
Old 06-18-2012, 08:45 PM   #3
Rewards Points: 13,748
Check to see if the check valve is on backwards. There should be an arrow or the words in and out on it.
Old 10-14-2012, 04:20 PM   #4
I am having the same exact issue! Very frustrating. Richo did you ever figure out the answer to this problem??
bird2103 is offline   Reply With Quote
Old 10-14-2012, 07:03 PM   #5
Rewards Points: 462
Yes I did find out the problem from a rep at Liberty. They originally told me that the pump could not be completely horizontal, that it had to be tipped at an angle or it would get caught in a cycle or some sort.
I had tried tipping it, about 15-20 degrees but that didn't make a difference. It turns out that it needed to be tipped at a full 45 degrees. Seems strange but now it works.
I don't recall reading this in the installation manual though.
Old 10-14-2012, 07:47 PM   #6
That is strange. How were you able to tip it, wasn't it connect with a straight piece of piping? Or did you connect with an elbow or angled piece? Thanks for the feedback!
Old 10-14-2012, 08:04 PM   #7
Rewards Points: 462
The pump is threaded onto a T-fitting that connects to the discharge so it can be twisted/tilted slightly in either direction.
Old 10-14-2012, 08:44 PM   #8
Rewards Points: 610
I'm with AllenJ..check to make sure check valve is closing at AC pump otherwise battery pumped water wil follow path of least resistance back to pit through the AC pump
techpappy is offline   Reply With Quote
Old 04-30-2015, 10:42 PM   #9
Rewards Points: 2
Tilt is the answer
Richo, you are a friggin' G. I spent 4 hours plumbing in a sump and back up. New check valves, the whole kit and kaboodle. Everything worked...except the back up, liberty 441. It would run...but not move water.
Took your advice, tilted er 30 degrees or so and it jumped out of whatever trance it was in. After, you can set it back to level and it will suck like a hoover.
Thanks bro, saved me a huge headache.
Redman
jredman is offline   Reply With Quote
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
sewage ejector pump check valve ogbill Plumbing 3 04-17-2012 11:28 AM
Sump pump help jazzyj Plumbing 10 09-12-2011 07:55 AM
Question about sump pumps and check valves lennyseleven Plumbing 3 11-08-2007 10:33 AM
Sump pump re-hab mpking Plumbing 1 11-07-2007 11:29 PM
