BackFlow Preventers And Pressure Reducers! - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-23-2011, 07:17 PM   #1
Lightbulb
BackFlow Preventers and Pressure Reducers!
I am renovating a 1920 house! The house is a duplex and now being turned into a triplex. My next mission is the plumbing. I am using Pex. The main line will be 1" with 3/4" branches and 1/2" copper stub outs connected to compression fitting stop valves. My water pressure is around 100psi(city water). So I am going to have to install a Pressure Reducer Valve. I have been reading a lot online, and it says PRV's make it a closed system. Will I have to install expansion tanks on all 3 water heaters? Where do I install the PRV? Do I need a Back flow Preventer? If so, does that go before or after the PRV? I know I need a BFP on my sill cocks and if I am having irrigation. My city is based off the Uniform Plumbing Code. I have the IPC because the bookstore didn't have the UPC. I am just trying to make sure that I get everything lined up before I have to redo things. I have everything figured out except the dang PRV and BFP. I am sure the manufactuer has instructions or I can call the inspector but I would like to hear other opinions.
daltinator is offline   Reply With Quote
Old 05-23-2011, 08:01 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 352
Your PRV should be in the house, after the shut off valve. Preferably in a location always accessible for service. Set it for about 60#, no more then 80#
With a PRV, you will need expansion tanks. My UPC inspector says one for every heater. Not sure if I'm convinced though.
As far as backflow prevention goes, it will be up to your inspector. Usually not required here.
The Following User Says Thank You to TheEplumber For This Useful Post:
daltinator (05-24-2011)
Old 05-23-2011, 08:11 PM   #3
Just call me Andrew
Rewards Points: 1,020
Why do you need an expansion tank with a PRV?
Andrew
secutanudu is offline   Reply With Quote
Old 05-23-2011, 08:25 PM   #4
Plumber
Rewards Points: 352
Simply put- PRV's have spring loaded diaphragms that open and close as needed. If closed, excessive pressure caused by hot water expansion cannot be absorbed into the water main.
Old 06-02-2011, 05:47 PM   #5
I think some PRV valves allow backflow - at least I'm quite sure the one I bought and installed stated that it did. *shrug*.
Mrdippy is offline   Reply With Quote
Old 06-03-2011, 08:23 AM   #6
Plumb or Die!
If PRV's were real backflow preventors, we wouldn't need backflow preventors. Heard this arguement a bjillion times.
plumber666 is offline   Reply With Quote
Tags
backflow valve , plumbing codes , pressure regulator valve , water heaters
pressure reducer valve and backflow preventer bluebird5 Plumbing 13 02-01-2011 08:28 PM
Gas Boiler Automatic Fill and Backwash Preventer dwlodyka Plumbing 1 12-20-2010 05:14 PM
