Backflow Preventer On Water Heater In Well-water System - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-08-2012, 10:54 PM   #1
Backflow preventer on water heater in well-water system
My house water is from a private well.
When I was changing my whole-house sediment filter, the relief valve on the water heater popped. I guess this is due to the fact that I closed the valves on either side of the filter housing to swap out the filter, and pressure that would normally be taken up in my pressure tank had no where to go. (This hasn't happened before, but this is only about the 3rd time I've changed the filter since I had a new water heater installed last fall.)
Anyway, reading up on what happened led me to discover that backflow preventers are required in many locales for water heaters. Is this true for private well systems? Or, if not required, is it a good idea? Could the backflow from my water heater be providing a steady stream of nasty little bugs that love to hang out in my pressure tank? It seems like the hot water tank would be the last place to worry about causing contamination upstream, but then why is backflow prevention often required for hot water tanks?
Thanks much!
pnschi is offline   Reply With Quote
Old 09-09-2012, 08:21 AM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 986
I can only speak for well systems i have worked on in Florida, check valve required on water heater when the unit is bottom fed.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 09-09-2012, 11:33 PM   #3
Thanks for you reply. The water heater is top-fed.
Old 09-10-2012, 09:21 AM   #4
Rewards Points: 1,440
Add a small expansion tank above the water heater (or anywhere in the system with no valve or check valve between it and the water heater) to stop the popping of the relief valve.
Old 09-10-2012, 09:59 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
You do not need a backflow preventer on your water heater.
Journeyman Plumber
Tags
backflow preventer , water heater , well water
Water heater issues?!? NJdan Plumbing 1 06-04-2015 08:42 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 12:35 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 06:23 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
