Backflow Preventer Adapters Keeps Spitting Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-14-2012, 01:31 PM   #1
Backflow preventer adapters keeps spitting water
I bought several of those little brass backflow preventer adapters to put on the faucet end of my garden hose. Now I found out that each time somebody turns on/off the other faucets in bathroom or kitchen, these little vacuum breaker-type of backflow preveners will spit out some jets of water for a second.
Is this normal? It's kinda annoying and it keeps my faucet area wet.
htabbas is offline   Reply With Quote
Old 06-14-2012, 04:52 PM   #2
DIY staff
Rewards Points: 7,174
That is normal---you must be leaving the hose bib turned on and using the hose sprayer as a shut off---
If the hose ever bursts you will end up with a mess---
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
