#1 |
backflow device on outside faucet
Our outside faucet has a fine thread backflow device attached (code in our town). Water pours out of the little holes in the top part and no stores sell the fine thread, only the regular thread replacements. The plumber that put it on will only replace the device if I pay the full 120.00 per hour.
Any ideas where I can buy the fine thread backflow device-it says ABP USA Anti-siphon Pat # 228 with a few letters I can't read. Stores (ACE, Home Depot) sell the little device but only the regular thread one, not the fine thread and there are no adaptors. Help! thank you, Claudia |
#2 |
the Musigician
a good PLUMBING SUPPLY shop should have the right piece, and also an adapter.
DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes! |
#3 |
take the old one out and take it with you to the suppliers and see if they can make it work or find something that will work
#4 |
In most cases, the fine thread is to prevent you from attaching a hose without a backflow preventer. You will not normally find this type at Big Box stores. Try a Plumbing Supply store.
If you have never made a mistake, you haven't done much. |
#5 |
Licensed P.E./Home Insp
Be careful. Back flow prevention device installers also carry (or should carry) certifications for BFP testing. The BFP rules in my state require a certified test report, with the results going to the local building department. Can't get a CO without that that certified test report. Who does the test? In my area all of the legit plumbers carry certifications for BFP testing.
If you install it yourself, and the town requires a test report or annual inspection and test, you'll have to hire someone to come out and test and certify the installation. If the device fails the test, then it will have to be adjusted or replaced. Last couple BFPs I installed (RPZ air gap type) needed adjustment there on the spot. Luckily I knew what to do, otherwise the tech would have left, and still charged us.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#6 |
Never heard of what Aggie is talking about for an outside faucet. This testing is required for sprinkler systems. On a faucet, it is called a vacuum breaker. On a sprinkler system, it is called a backflow preventer and is much more complicated.
#7 |
I see the word faucet. For some reason I had irrigation system on the brain. My bad.
Try Arrowhead's website, arrowheadbrass.com, and see if your model is there. They might help you sort it out.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Aggie67; 05-06-2009 at 03:16 PM. |
#8 |
Arrowhead Brass Products
http://www.arrowheadbrass.com/ makes several products, a hose bibb with machine threads to match the Anti-Siphon device with a Hose Thread on the end. Try part numbers 59ABP (Hose Thread) or 59BFB (machine thread) - it's not specified which end is referred to but I'll bet it's the 59BFP you want. A repair kit is available, see the spec sheet for the 480 series. Also try Replacement Part Number 59BFPCHR (also shown as PK1390) price on Arrowhead's web page is $22.02 http://www.arrowheadbrass.com/op_cha...dimensionName= |
#9 | |
backflow device on outside faucetQuote:
#10 | |
Doing it myself
Journeyman Plumber |
| Display Modes | |
| New Delta faucet drips | KE2KB | Plumbing | 10 | 02-28-2012 10:34 AM |
| Washing Machine Faucet | handy man88 | Plumbing | 5 | 03-23-2009 02:25 PM |
| No hot water pressure at kitchen faucet | tracker883 | Plumbing | 2 | 12-30-2008 06:10 AM |
| Faucet Drain Lever Installation | DK75 | Plumbing | 3 | 05-21-2008 11:08 AM |
| Repair outdoor faucet? | mx13 | Plumbing | 3 | 04-09-2007 07:08 PM |
