Backfill Trench In Slab For Drain Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-14-2010, 10:31 PM   #1
backfill trench in slab for drain pipes
I am laying out plumbing for a bathroom on concrete slab. when filling concrete around drain pipes, can I just pour right up against the pipes or do you need some gap around the pipes? I vaguely recall the inspector saying something about sleeves on the pipe when I last talked to him a few weeks ago, but I can't remember now.
acerunner is offline   Reply With Quote
Old 10-14-2010, 10:34 PM   #2
They need to be sleeved to keep them from cracking as the concrete cures/settles.
Ishmael is offline   Reply With Quote
Old 10-14-2010, 11:06 PM   #3
what kind of sleeve do I need to use? Does it stay there permanently?
Old 10-14-2010, 11:27 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 350
For drain lines use a couple wraps of sill seal. (a couple extra wraps on the toilet stub allows room for the flange to glue on) Thats the thin insulation frammers use between concrete and the green plate. hold it in place with duct tape. It only needs to be as tall as the concrete is thick. For water lines, pipe insulation works good.
Old 10-15-2010, 04:31 PM   #5
based on that, I assume i have to remove the wraps after concrete cures?
Old 10-15-2010, 10:26 PM   #6
Plumber
Rewards Points: 350
Thats correct. I use a drywall jab saw or a long hand held wood sawzall blade to clean out the wrap. Only takes a minute or two.
Old 10-15-2010, 11:16 PM   #7
thanks!
Oh no...the guy who I hired just concreted today with no sleeves...
Goodluck and thanks for the info
ShutOut13 is offline   Reply With Quote
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Drain pipes in slab acerunner Plumbing 0 10-04-2010 01:24 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
backfill & grass over a gravel trench ??? linboomer Landscaping & Lawn Care 4 05-09-2009 07:54 AM
Finding waste pipes under a slab Eva Plumbing 15 01-02-2009 03:12 PM
