Backed Up Bathtub - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-07-2007, 08:44 PM   #1
Exclamation
Backed Up Bathtub
hi,
the bathtub in my house is backed up, and when i plunch it, i get leaves and dirt like sediment. looks to me like a cracked drain pipe. the house is built on a slab, no crawl space. how do i look into this problem???
bob
bobo is offline   Reply With Quote
Old 01-07-2007, 09:45 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
You will need to try and clean out the drain, they have cheap hand crank augers you can get and try with, take overflow plate off and run it down through there.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Foil Backed OSB DaveHembree Roofing/Siding 26 08-27-2013 02:46 PM
Tiling over a bathtub lip The Kid Remodeling 19 02-04-2012 12:46 PM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 06:45 AM
peeling bathtub drunkugly Plumbing 4 07-13-2006 09:35 PM
Leaking Bathtub woodinville guy Plumbing 3 09-01-2005 02:32 PM
