Back Up Sump Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-14-2011, 07:41 AM   #1
Rewards Points: 154
Back up Sump Pump
OK Pro's do I want a box store back up sump pump or should I go to a pro and get one that is more commerical grade. I heard some bad reviews on the watch dog product you get at box stores. thanks, G
turbomangt is offline   Reply With Quote
Old 02-14-2011, 08:22 AM   #2
Experienced
Jackofall1's Avatar
Had a watch gaurd for about 10 years, maintained battery every year or so, never failed me when it was needed, and it was needed a couple of times. I did go out and get a second battery to connect in parrallel, so I had lots of longevity.
Mark
Old 02-14-2011, 08:28 AM   #3
Rewards Points: 154
I have heard that sealed battery's last longer, rather than the acid type like in the WD, I also know they make pumps that work in the event the main pump fails, lots of different options here
Old 02-14-2011, 08:29 AM   #4
Rewards Points: 1,538
Test the backup pump every once in awhile. (Turn off the power to the "main" pump for a few fill/empty cycles.)
Old 02-14-2011, 08:32 AM   #5
Experienced
Jackofall1's Avatar
The basement watchdog charger system has a probe that is inserted into the battery which alarms if the electrolite gets low (bout once a year) fill with distilled water and its good to go.
Mark
Old 02-14-2011, 08:40 AM   #6
Rewards Points: 154
I see all kinds of price levels, $200-$600
Old 02-14-2011, 09:18 AM   #7
Experienced
Jackofall1's Avatar
Well when I bought mine, big box store, don't really remember how much but I believe it was around $250 10 years ago, and an extra battery was another $70 but that was like 8 years later, as a just in case kind ot thing.
Mark
Old 02-14-2011, 05:06 PM   #8
DIY staff
Rewards Points: 7,174
SUMPRO Platinum
Here is the top system that I could find----
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
sump pump water lower than normal???? fabian Building & Construction 18 12-05-2009 05:26 AM
Sump Pump Electrical Problem loftezy Electrical 5 09-06-2009 06:14 PM
How does this sump pump system look and how would I add a battery back up? Jay Nel Plumbing 4 07-22-2008 03:48 PM
looking to upgrade sump pump coeng Plumbing 14 06-04-2007 03:08 PM
