Back Up Sump Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-17-2012, 03:38 PM   #1
Rewards Points: 324
Back Up Sump Pump
Hello,
I am currently thinking about adding a second pump as a back up to my primary back up sump pump in case the main one goes bad. My plumber is pushing me to Pro Series pump which I don't have any issues with. I do have a all house generator with auto transfer. My questions are as follows:
1. Is battery back up on the 2nd pump an overkill and waste of money since the batteries need replacement and probably won't be needed?
2. Which sump pumps do you guys recommend? Again,he is pushing me to Pro Series 2400 with maintenance free battery which seems to cost arm and leg
Thank you
sbkim is offline   Reply With Quote
Old 07-17-2012, 11:15 PM   #2
Rewards Points: 352
zoeller m-53. You don't need a battery back up you have a generator that kicks in automatically.
plumberinlaw is offline   Reply With Quote
Old 07-18-2012, 07:21 AM   #3
Rewards Points: 324
Thank you - I figured it's a bit too much of contingency planning.
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Back up Sump Pump turbomangt Plumbing 7 02-14-2011 06:06 PM
sump pump water lower than normal???? fabian Building & Construction 18 12-05-2009 06:26 AM
Sump Pump Electrical Problem loftezy Electrical 5 09-06-2009 07:14 PM
How does this sump pump system look and how would I add a battery back up? Jay Nel Plumbing 4 07-22-2008 04:48 PM
