Old 10-14-2012, 03:09 PM   #1
back flush of cold water line
Hello, I have a kitchen fixture with low pressure,think sediment block.I do not know how much outlet max. psi to regulate compressor for and for how long 3 min,etc? my compressor is portable type 1.5hp/twin stack tank/and 155 psi max outlet pressure. can you advise here so i don,t damage lines too much pressure ,blow out for to long.thanks Don
dgorbutt142 is offline   Reply With Quote
Old 10-14-2012, 09:40 PM   #2
Have you first removed the aeriator to see if it's plugged up?
Disconnected the lines under the fauce and ran some water into a bucket.
I've never once seen water line need to be blown out with air unless it was to winterize them.
Old 10-15-2012, 08:19 AM   #3
thanks for advice joe from VA, aeriator is off and clear,but will remove lines,that might free block.thanks again Don
Old 10-15-2012, 08:30 AM   #4
One kink in a supply line can cause this.
Old steel pipes for sure can cause it. They rust up from the inside out.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 01:59 PM
Need Advice on how to Correct Low Water Pressure Joe Tilghman Plumbing 51 04-13-2012 01:11 PM
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 01:05 AM
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 10:03 AM
