Back To Back Toilets,suck The Trap Seal ! - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-28-2010, 09:58 PM   #1
Question
Back to Back toilets,suck the trap seal !
So check this out, a friend of mine that is a great plumber had a odd thing happen. First of all all waste and vents are installed and sized correctly. They were also scoped by a video camera, PERFECT waste and vent.
Here is the thing.....back to back toilets ( ABS Waste) Kohler "Hi-line" Water Closets installed.
One or the other of the Toilets will loose its trap seal (it gets sucked or blown out) Kohler says "yep this happens sometimes with the 1.6 gpf large Flapper type toilets ......WHAT !
I suspect this is possible but more likely a piece of string or dental floss is siphoning out thew trap.
If it is just the quick or fast flush toilet then the Toto " Drake " would also do the same thing.
Regular 4"x3" ell's, 3" waste,2" vent !
comments ?
Scott the Plumb is offline   Reply With Quote
Tags
black mountain plumbing , great plumber.... , toilets , trap seal gone
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
Severe Drainage Issue kirridam Landscaping & Lawn Care 11 07-25-2009 06:44 AM
Cat trap fever radtek General DIY Discussions 13 05-31-2009 06:18 PM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 10:10 AM
Attic A/C Unit Condensate Trap bardad1022 HVAC 3 06-25-2007 07:30 PM
