Back To Back / In Series Toilets - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-21-2012, 02:28 PM   #1
Back to back / in series toilets
I have 2 toilets installed back to back and in series on the same waste line. They are attached to a hefty 3 inch cast iron pipe and would be very difficult to update with a wye or other fitting.
Is there anything to do vent wise to prevent issues down the road? I hear the new Toto toilets can cause problems with back to back toilets.
This is in Illinois.
captmorgan is offline   Reply With Quote
Old 10-21-2012, 04:30 PM   #2
Rewards Points: 6,652
Really need pictures or drawings.
Old 10-21-2012, 08:36 PM   #3
Here's a pic. The connection at the vent looks to be a sanitary tee.
Back to back / in series toilets-back_to_back_toilets.jpg
Old 10-21-2012, 08:36 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 450
Sounds like they're connected to the stack using a double san tee with a common vent off the top. If so, it's properly vented if the vent is 2" or larger. Short of tearing it apart, not much you can do.
enlighten me-- What does the Toto do in this situation?
Old 10-21-2012, 08:48 PM   #5
So, are you going by the slanted and skewed Consumer Reports editorial on the Toto Toilets? If you really want some good opinions on Toto, go to the Terrylove.com forums. You will find plenty of info about them on his forum site.
Old 10-21-2012, 09:25 PM   #6
There was some talk on the plumbingzone about back to back Totos. Something about the higher velocity flushing of new toilets causing problems. Its also in the Toto install instructions not to use a double san tee.
I don't want to rip out the cast iron, I just don't want flushing or code problems. Hopefully with a 3" vent it should be good.
http://www.plumbingzone.com/f7/back-back-toilets-17513/
Old 10-21-2012, 09:58 PM   #7
Looking some more I think what I have is a sanitary tee (not double) connecting two toilets in series. The drain to the sewer is not in the middle of the toilets but is off to the left in my picture.
Still trying to find the Illinois code that would say if this is allowed.
http://www.terrylove.com/forums/show...tion-Questions
Old 10-21-2012, 11:22 PM   #8
Plumber
Rewards Points: 450
Your picture does not clearly show the drainage fittings that connect the toilets. But from what I see- it looks like a double san tee. I haven't ran into the issue you or the Love thread describes, but what appears to happen is that the waste water travels across the vertical drain. Venting modification probably won't help. Changing the double san tee out for a directional fitting (fixture cross) or using a different toilet will though.
Putting carpet back xandrew245x Flooring 1 09-19-2012 09:57 AM
Back Up Sump Pump sbkim Plumbing 2 07-18-2012 07:21 AM
toilets clogged erb Plumbing 8 08-17-2010 10:44 PM
Need help making a 'back band' around window/door casing. RickDel Carpentry 3 07-15-2010 04:13 PM
sagging kitchen off back of house DanBress Building & Construction 12 03-03-2008 10:20 PM
