Avante Shower Cartridge Replaced, Now Water Flow Is Low? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-16-2010, 01:42 PM   #1
Avante shower cartridge replaced, now water flow is low?
I have just finished replacing a defective Price Pfister "Avante" style shower cartridge in my shower. All is working and there are no more leaks however the water pressure to the shower head is not as strong as before?
Are there low flow water restrictors on these cartridges that need to be removed? The cartridge I purchased was a Danco PP-8 replacement.
Any ideas or help would be appreciated?
Thank you.
tmac4 is offline   Reply With Quote
Old 02-16-2010, 02:21 PM   #2
Hello TMAC4 I looked the replacement # up they show a number of mfg# 974-292 and that is the Price Pfister Avante exact number for the cartridge. As for the other name and number you list is that after market name and number that could be the problem ??? . Kerry
kerry42 is offline   Reply With Quote
Old 02-16-2010, 02:41 PM   #3
Yes I have thought of this. However the only replacement I could find quckly was the Danco PP-8 which is Danco's replacement part for PP's Avante.
The parts do look nearly identical.
The 974-292 (on top) This type came out of my shower.
The PP-8 (on bottom) this is identical to the replacement put in.
I guess I need to find a local supply ( in Houston) for these as I cannot trust getting the right one over the internet site unseen. I have seen the all plastic one lised as 974-292 as well as the one with the metallic insert.
Old 02-16-2010, 04:53 PM   #4
Is the one on top the original one ??? from Price Pfister it appears to be a little different slightly on the end ,but don't know if that what causing your problem for sure . there is possibly that some foreing matter might be stuck in valve body might want to try flushing that out ,does that valve have stops built into valve ?. if so leave cartridge out and crack open the stops a little bit and see if it will disloge something ,but be careful water is going to come staight out at you .also if valve does have stops are you sure that they are open all the way or any other valve that might have been turned off be for you change out the first one just a thought ???????
Old 02-19-2010, 02:45 PM   #5
Ha! The solution was so simple! I checked my shower head and found it clogged with debris. I guess turning the water off and on again caused this as my shower head was running just fine prior to the new cartridge being installed.
I never would have thought that my shower head could be so clogged up so fast. At least this was the first thing I checked before attmepting to fool with the cartridge again.
so I guess either cartridge type is just fine!
leaking hot water from the single valve kohler shower head B1026 Plumbing 2 01-11-2010 09:48 PM
Low Flow Problem at Shower Head steveo178 Plumbing 4 12-27-2009 12:59 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 08:07 PM
