Automatic Shut-off Valve Hot Water Heater? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-14-2010, 11:07 AM   #1
Automatic shut-off valve hot water heater?
Has anybody ever installed one of these automatic shut-off valves for your hot water heater?
I looked at my set up but it looks like I will have to cut and solder pipe. What do you think?
And any opinions? I'm just a little paranoid, I've had two people I know in the past 2 months have their actual water heater burst and flood their house, and mine is right there in a closet in the main room of my small house so a little extra insurance would give me some peace of mind.
thanks
snosurfa7 is offline   Reply With Quote
Old 06-14-2010, 11:07 AM   #2
I guess it would help if I gave you the link!
http://www.amazon.com/OnSite-Pro-Wat.../dp/B000AQAQUS
Old 06-14-2010, 11:57 AM   #3
I would be worried after reading one of the reviews that stated the valve failed to close while doing a test after one year. Safety devices are nice, when they work.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 06-14-2010, 04:44 PM   #4
WaldenL's Avatar
Rewards Points: 268
Of course, if the valve fails to close you're no worse off than if you didn't have it in the first place. So if it fails 1% of the time (just a number I made up) it will save your a$$ 99% of the time. It's not very expensive, seems like good "insurance" to me. Wonder what other options are.
OP: Yes, looks like cutting and soldering (could always use shark-bites) would be required. Soldering is a good skill to learn anyway, so bite the bullet.
WaldenL is offline   Reply With Quote
Old 06-14-2010, 04:52 PM   #5
It's $150 plus your labor for "a lifetime premium for flood insurance" for your water heater.
How much does your homeowner's ins. co. charge per year for you to be covered for pipe breakage?
Old 06-14-2010, 09:21 PM   #6
Nice thought Yoyizit, but in 35 years as a Plumber, I have yet to see a water heater under 12 years old burst. Then there's the water in the tank that is still going to soak the floors. Pipe breakage coverage costs the same no matter what "devices" you have in place, if they fail.
Old 06-15-2010, 06:32 AM   #7
Rewards Points: 1,216
Sounds like a good idea.... I would test it at least once a year to exercise the shutoff to make sure it works.. just simulate an emergency once or twice a year...Don't forget or it will let you down.
COLDIRON is offline   Reply With Quote
Old 06-15-2010, 11:44 AM   #8
So looks like a cut and solder deal then...
If I had a hot water heater in a basement or garage I probably would not worry about it but given its location in my house it seems like a cheap (relatively speaking) form of insurance. Because although homeowners would cover a burst water heater (I checked) it would still be a major pain to have to redo my entire house versus just one room. Worth a shot, guess I'll see...
Old 06-15-2010, 01:38 PM   #9
Rewards Points: 3,130
Looks like a waste of time and money. Modern water heater virtually never "burst". Now washing machine hoses, that's another story. Spend your money there.
Old 06-15-2010, 02:19 PM   #10
Your insurance company or the CPSC may tell you what is the most likely internal cause of house flooding, but hoses probably occupy 1st and 2nd place.
I guess it primarily depends on the PSI and the number of on/off cycles over time.
Are you on well water?
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 07:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 05:40 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
