Automatic Shower Limiter - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-17-2010, 11:50 AM   #1
Rewards Points: 858
Automatic shower limiter
Hi;
I live in a house with my 13 year old niece, and like so many her age, she takes very long (15 minutes) showers.
She sometimes even leaves the shower while the water is still running.
I even built an extension for the shower arm, so that she could reach the shut-off we installed on just above the head, but she never uses it.
So, I'm thinking of an automatic device that will limit shower time either by time, or by flow. The device needs to be "child-proof" in that she cannot easily press a button to reset the flow and get another 10 minutes out of it.
I have seen one device on the market; "The Shower Manager", but the reviews for the product pretty much tell me what I expected reading their website; it's a piece of junk.
Does anyone know of a device that would suit my needs, for about $25 or less?
FW
Ultrarunner2017 is offline   Reply With Quote
Old 05-17-2010, 11:59 AM   #2
the Musigician
DangerMouse's Avatar
Why not just reach back and turn off the output on the hot water heater? .... she'll finish REAL fast!
DM
Old 05-17-2010, 01:51 PM   #3
Rewards Points: 858
DM
Funny you should mention that. It is exactly what I came up with about 1/2 hour ago!
Then, when she complains that the water got cold, I'll just play dumb, and tell here the hw heater ran out of hot water.
FW
Old 05-17-2010, 03:08 PM   #4
the Musigician
If you turn it off slowly enough, she'll just think she's used up all the hot water... and MAYBE hurry and get out?
DM
Old 05-17-2010, 09:16 PM   #5
Rewards Points: 858
DM
Sounds cool
FW
Old 12-01-2010, 10:27 PM   #6
Need that limiter too
I've been wondernig the same thing for years. My boys are now 14 and showers are getting longer. I did have a flow meter in line with the shower pipe, and that told me how many gallons were used. They could use it too. But it would not stop the flow. There HAS to be some kind of valve that meters flow. I may try the meter again and see if they'll try to stay under some limit.
Steve R is offline   Reply With Quote
Old 12-01-2010, 10:44 PM   #7
ok plumbers it sounds like someone could invent this thing and make a bundle. I am thinking of something like the mechanical automatic shutoffs that you hook to your garden hose then you turn the dial for an hour and it uses the flow of water to move the dial. By the way my wife drains a 60 gallon water heater at least twice a week when she showers.
warnerww is offline   Reply With Quote
Old 12-02-2010, 12:13 AM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 444
You take a "normaly open" solenoid valve, install it before the shower valve, (perhaps hot side only) energize it through a switch or timer that is located outside the bathroom. When the alloted time is up flip the switch
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 08:07 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
