Augusta Bathroom Sink Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-25-2013, 08:24 PM   #1
I have an Augusta batroom sink with a two handle, single hole faucet assembly. There is no manufacture name on the assembly but it looks just like the "Fima Frattini" Nameeks S5041 with dome handles. The handles are mounted at 2 and 10 o'clock into the base of the faucet. There are no access holes in the handles for access to locking or set screws. How are the handles removed ???
lz35mv is offline   Reply With Quote
Old 02-25-2013, 08:26 PM   #2
Rewards Points: 13,960
Post a picture.
Old 02-25-2013, 09:41 PM   #3
DIY staff
Rewards Points: 7,174
Often the bell shaped part under the handle is threaded on ===grab it an see if it unscrews---the handle is actually built into that bell.
Old 02-26-2013, 09:49 AM   #4
Roofmaster
Rewards Points: 2,210
Heat uppa soma marinara gravy and pour ona da handles, shesa pop right offa!
Old 02-26-2013, 10:06 AM   #5
Look like this?
http://www.thebathoutlet.com/Bathroo...Fima-S5041~Buy
If so those round caps one the handles unscrew or just pop off, then you can get to the screw holding the handle on then the housing unscrews to get to the washers and stem packing.
Bathroom sink faucet drgloria777 Plumbing 1 03-24-2011 10:00 AM
Bath faucet pop-up drain rod won't fit sink hole location seavlad Plumbing 7 02-03-2011 06:23 PM
bathroom sink pressure issue. tgamblin Plumbing 4 04-27-2009 12:21 PM
laundry sink needs wall-mount faucet - can I cheat? bluebee1314 Plumbing 2 04-05-2008 11:45 AM
Adding an additional sink in Bathroom tke402 Plumbing 1 04-26-2007 09:14 PM
