Attention: Mat Muenster, OR To Whom It May Concern / Right Match - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2014, 02:06 PM   #1
Unhappy
Debbie Louie
Subject: Clogged/Back Up Bathtub,Toilet
Duplex was builded about Late maybe 1940's or SO!!! No Insituaiton whole place. HATE IT! Place Feels Very Cold!
Moved In December 1, 2013. I use professor amos superfast drain cleanser with accelerated forumula...DID NOT WORK! HATE WHAT FOLLOWS! STALKING ISSUES/PROBLEMS!!! IT JUST MADE IS WORSE, WAITED 4 HOURS; NOTHING HAPPENED. I will be getting refund soon. $35.00 w/shipping
I did see allot of stuff backing up into tub, look awful looking, bites of black and biege color. at first i thought it was tree and leafs..I didn't think so!
I can use the shower no back up, thanks goodness. I do have very long hair when i do wash my hair allot of hair goes down the drain. I know its one of problem.
What do you have that will get up and out of the drain, And FAST TO Unclog, Tub & Toilet. And Very Affordable!
About 5 months ago plumbers used camera I saw hold at (I think at the bottom of pipe..I think) change was $499.00. What Rap Off! Jerks! Wish My Brother Can Get His Money Back.
Debbie
Debbie21 is offline   Reply With Quote
Old 02-28-2014, 03:21 PM   #2
Rewards Points: 1,694
Go to a big box store buy a product called "the Works", toiled bowl cleaner, pour in your drain, it may take more than one bottle, but it will dissolve the gunk build up of whatever has accumulated over many years.
GOOD LUCK WITH IT. IT WILL WORK.
ED
de-nagorg is online now   Reply With Quote
Old 02-28-2014, 05:17 PM   #3
added instruction
ED
After pouring the whole bottle in the drain, let it sit at least 15 minutes to dissolve the gunk in there, then get your largest cooking pot, and boil a pot of water, at least to boiling point, While the cleaner works more, pour this boiling water down the drain in the shower.
the combination of the cleaner and the hot water will flush out the pipes very well.
ED
Old 02-28-2014, 05:51 PM   #4
Rewards Points: 1,868
You need to get your sewer cleaned professionally if toilet is not working.
Old 02-28-2014, 06:21 PM   #5
Rewards Points: 20
Please, please do not ever use chemical drain cleaners. As you have found out they often do not work and you risk serious injury to whoever you eventually have clear the drain. Call a professional plumber to clear the drain and you will be rid of this headache.
SHR Plumber is offline   Reply With Quote
The Following 3 Users Say Thank You to SHR Plumber For This Useful Post:
daveb1 (02-28-2014), Ishmael (03-01-2014), joecaption (02-28-2014)
Old 02-28-2014, 10:29 PM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 994
499 jerks money back please explain?
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-28-2014, 11:12 PM   #7
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
Are you on city sewer or a septic system. If you are on septic do not use drain cleaners. Best way it to have the drain line cleaned with a snake.
gmaint is offline   Reply With Quote
Old 03-01-2014, 05:14 AM   #8
It seems she's upset that a guy would actually charge money (can you believe it?!?) to bring his $10,000+ worth of camera equipment to her home in one of his $40,000 vehicles full of thousands of dollars worth of other tools and materials likely with a helper he has to pay.
Ishmael is offline   Reply With Quote
The Following User Says Thank You to Ishmael For This Useful Post:
oh'mike (03-01-2014)
Old 03-01-2014, 06:53 AM   #9
DIY staff
Rewards Points: 7,174
So many folks see no value in diagnosing a problem-----
The funny thing is--this site exists because diagnosing problems is so difficult--and crucial to a correct fix----
"But you did not DO anything....."----
Old 03-01-2014, 07:11 AM   #10
An old Tradesmen
Rewards Points: 6,914
And I believe the OP thinks she is on a different site.
The Following 3 Users Say Thank You to beenthere For This Useful Post:
Ishmael (03-01-2014), oh'mike (03-01-2014), VIPlumber (03-01-2014)
Quarter Round for hardwoods - White or match the floor? mr_ekco Flooring 6 02-22-2011 06:00 PM
Who can mix paint to match home color exactly? darsunt Painting 20 06-20-2009 11:46 PM
how to match two different type of flooring cmacnulty Flooring 3 06-19-2009 03:36 PM
Staining to match ponch37300 Painting 3 02-14-2009 07:36 PM
French Doors That don't Match! terryb Building & Construction 21 12-17-2007 07:19 PM
