Old 04-28-2007, 03:53 PM   #1
Default Attaching water lines to floor joists
I am almost done framing my basement and I have to replace some of the clamps holding a couple water lines to the floor joists. The lines are copper. I found some copper clamps that will work great but I can't find any copper nails to secure the clamp to the joist. Is there such a thing or is there a different metal that I can use to attach the copper clamps?? I know if you use different metals with copper it will eventually rust so obviously I want to avoid that.
handyflyer is offline   Reply With Quote
Old 04-28-2007, 05:05 PM   #2
Master Craftsman
Big Dave's Avatar
We always used the plastic clamps.
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Old 04-28-2007, 05:36 PM   #3
Darylh's Avatar
Me to
www.geocities.com/edimprovement
Darylh is offline   Reply With Quote
Old 04-28-2007, 06:50 PM   #4
Plastic ones are already on there but they are 1 inch pipes. I am furring down from the ceiling by using 2x4 flat thus giving me 1.5 inches to work with. The plastic ones extend down too far.
Old 04-28-2007, 08:15 PM   #5
Journeyman Plumber
Ron The Plumber's Avatar
Yes gold colored drywall screws. There corrosion resistant
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 04-28-2007, 08:57 PM   #6
Copper nails? Copper is way too soft of a metal to be used as a nail. Maybe copper alloy, but I doubt it.
handy man88 is offline   Reply With Quote
Old 04-29-2007, 11:23 AM   #7
The nails are copper plated. You can find them where ever you find copper roof flashing. The last time I bought some they where at home cheapo.
Pipes is offline   Reply With Quote
Old 04-29-2007, 11:40 AM   #8
You're right. I saw them used onetime on a this old house episode.
Old 04-30-2007, 12:43 PM   #9
In way over my head.
Clutchcargo's Avatar
Brass works.
You'll never be sorry you bought the best.
Clutchcargo is offline   Reply With Quote
More On This Topic
In bi-level houses, transporting soiled laundry downstairs wastes considerable effort. A simple solution is to transform a closet into a laundry chute. There's no need to give up an entire closet; a small addition against one wall can be an effective... Read More »
Now we are going to do the soldering or the tacking of the piece together with little beads of soldier at the joints. We take the already heated up soldering iron, it has been fluxed, and we just see if we can tack this together with a little bead here... Read More »
I’m Lee. I have a degree in architecture and about ten years construction experience, and we’re installing a new dishwasher. The water inlet, which is, everything’s located on the bottom. You just want to take some Teflon tape and... Read More »
How to MIG Weld a Lap Joint
How to MIG Weld a Lap Joint by Expert Village
Hi I'm Mike Rogers and we are making this video for expertvillage.com on the use of mid welder. Our next project would be how to create a simple lap joint. This is technique often requires for joining any manner of piece of steel when you need to extend... Read More »
A deck can beautify any home and increase the home's value. Like a house, a deck that isn't on a solid foundation is a dangerous thing. Be sure to build a solid deck by correctly installing the deck girders. This can be done in the following manner. Read More »
new water lines JahDoos Plumbing 11 02-22-2007 11:43 PM
Insulating Hot Water Lines jeepwillies Plumbing 1 11-21-2006 04:41 PM
air in water lines chattiechick Plumbing 2 11-01-2006 02:36 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 12:31 PM
Old Water Supply Lines in Kitchen and Bath Faucets skittlzski Plumbing 2 08-08-2006 11:13 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
