Attaching A Fernco To A Cast Iron Elbow - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-17-2012, 09:43 PM   #1
Attaching a Fernco to a Cast Iron Elbow
Is it OK to cut the hub off of a cast iron elbow and use a fernco?
Fisher252 is offline   Reply With Quote
Old 07-17-2012, 09:46 PM   #2
Rewards Points: 13,724
No, not going to work.
What is it your really trying to do? A picture may help.
plummen (07-18-2012)
Old 07-18-2012, 07:42 AM   #3
Why wouldn't it work?
I am really wanting to attach pvc to a cast elbow...
I should be able to get a picture tonight.
Old 07-18-2012, 08:24 AM   #4
DIY staff
Rewards Points: 7,174
leave the hub and use a rubber doughnut to join the PVC to the hub---much cleaner and better flowing job.
Old 07-18-2012, 10:24 AM   #5
Here is a picture. I thought about a doughnut, but I have never used one, and it seems like a lot more trouble...
Old 07-18-2012, 10:30 AM   #6
DIY staff
How come it would be more difficult?
Pry out the lead--remove pipe from hub--add PVC to the doughnut---pound the assembly in to the hub with a block of wood and a hammer---mark the PVC where it meets the doughnut so you will notice if the pipe is working its way out as you pound.
Sure beats cutting the iron elbow---a chain breaker might help--but cutting is much more work and expense than wiggling a hub apart--Just a word of experience---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
ben's plumbing (07-18-2012), jaydevries (07-18-2012)
pvc to cast iron hub using fernco-can't get it! What have I done Plumbing 10 01-22-2014 07:55 PM
pinhole leak in cast iron elbow for water heater. tractorfarmer HVAC 23 01-16-2012 05:21 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
smoothening cut cast iron pipe before mounting fernco coupling amakarevic Plumbing 6 11-15-2007 05:39 PM
