Attach Shower Surround To Studs On Outside Wall? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-25-2008, 08:53 AM   #1
Attach Shower Surround to Studs on Outside wall?
I am going to be in need of replacing my 32x32 shower stall in the bath off our master bedroom. Since this is an already cramped space I barely have enough room to pull this off. The instructions and movie for this unit show that you are recommended to just secure/nail this shower surround directly to the studs not needing to use green or cemet board backer.
Because one of the side walls is the outside wall of the house, is this recommended/permitted? There will be the existing insulaiton and then outershell (cedar T-111) in front. Is it OK to put the surround on this frame or should greenboard or cement board be put there as another vapor and insulating layer?
Here is a link to the surround I was considering which has a photo.
http://www.sterlingplumbing.com/onli...d_num=62010100
BillyDIY is offline   Reply With Quote
Old 08-25-2008, 09:14 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
we never secure showers/tub showers over greenboard/drywall, it just doesn't work very well. On exterior walls they are insulated before we install the unit, and then secured directly to the studs.
Journeyman Plumber
Old 08-25-2008, 01:09 PM   #3
Thanks so much!
Shower Half Wall Framing Colbymom Building & Construction 7 08-01-2008 10:49 AM
Tub surround shower door issues Zharkov Plumbing 14 06-30-2008 10:52 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 06:17 PM
