Old 03-26-2007, 09:44 PM   #1
johns
Guest
Posts: n/a
Default AquaPEX purchase and installation by homeowner
I have seen several posting where the members of this forum have spoken about installing AquaPEX plumbing. My question is whether you guys are contractors or not. I am looking seriously at installing some AquaPEX lines in my home, but the couple of local companies that sell the stuff have told me that I need to be certified and be a licensed contractor. I have tried to explain that homeowners don't have to be contractors to work on their own homes, but that seems to go in one ear and out the other. Also, the Wirsbo site talks about training, but only for contractors. So, how am I supposed to get around all of this red tape. One final thing. I see that most new homes have this type of tubing installed. How are homeowners supposed to fix these installations?
Thanks for your help.
John
Old 03-27-2007, 03:08 PM   #2
Try a big box store they may not carry that brand but there are others they may even have a Saturday class to give you pointers. You'll be as good as any plumber in no time.
Zero Punch is offline   Reply With Quote
Old 03-28-2007, 09:09 AM   #3
RippySkippy's Avatar
I believe your observations about aqua-pex are right on...wirsbo has gone to great lengths to segregate their product from the home-owners and DIY'ers.
I had access to an expander tool, but chose to use DuraPex from Menards with the copper crimp rings. I wanted to have access to fittings and supplies with out the hassle, and from what I can tell, it looks like it will be a good system. Other than the crimping/clamping system...in your research I think you'll find that pex is pex, and it's the subtle differences in fittings and tools that seperates the different companies. Be careful when buying pipe/tools/fittings not all pipe has the same wall thickness and all items may not be compatable across brands.
Google Sioux Chief, they have wide assortment of fittings and tools.
Good luck!
RippySkippy is offline   Reply With Quote
Old 04-03-2007, 09:13 AM   #4
I agree with the first response go to one of the box stores and ask some questions.I put pex in on my owne throughout my house.I was going to break down and buy the expander/crimper but I was shown to quick conect fittings and how they work at the store so I bougt a few tried them out for a month in the coldest month and they worked great so I did the whole house in it.No one told me I had to be a contractor to install it good thing I wouldnt have listened to them also you will get some excelent advise on here if you run into any problems
clasact is offline   Reply With Quote
Old 04-30-2007, 02:45 PM   #5
i bought shark bites at the Home Depot to connect some pex to copper..
they work great... a bit expensive..but when yoiu only need 3 or 4...it's a lot cheaper than buying the crimping tool.
...and darn right inexpensive when you don't have to pay the plumber
lee polowczuk is offline   Reply With Quote
Old 04-30-2007, 10:26 PM   #6
Originally Posted by johns View Post
...I have tried to explain that homeowners don't have to be contractors to work on their own homes, but that seems to go in one ear and out the other....
Technically (at least here in Massachusetts), ANY plumbing done in any home requires a permit and inspection with the exception of simple repairs. If you install a new faucet on a sink, you are technically supposed to pull a permit, which homeowners cannot do...only licensed plumbers.
Ishmael is offline   Reply With Quote
More On This Topic
Starting a mobile home repair business is a natural step for the entrepreneur who has experience in housing construction or as a handyman. With the right tools and the right knowledge, you can start a mobile home repair business right out of your house. Read More »
Sealing cracks in your foundation or walls will not seal out radon completely. Radon is a radioactive gas that can cause lung cancer. Sealing cracks can, however, increase the effectiveness of a contractor-installed system to lower radon levels in your... Read More »
Secretaries are in high demand. Therefore, starting a secretarial service should be a financially sound move. The nice thing about this is you can do it from the comfort of your home. Following the steps below should help you profit from your secretarial... Read More »
A home improvement referral business benefits clients by eliminating the time involved to search for reputable contractors to perform home improvement projects. The service offers homeowners a list of pre-screened, pre-qualified contractors with a... Read More »
Verbal contracts seldom hold up in court, so if you're planning a home renovation, even if it's with a contractor who is personally known to you, you should always make a written agreement. You'll want to specify, in writing, the exact work to be... Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
