Aqua Brass Shower Valve Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-21-2011, 04:44 AM   #1
Handyman
Rewards Points: 512
aqua brass shower valve question
This shower valve has only one shut-off screw (hot water) but the cold water side has a silver insert...not a screw (see pic) so I can't shut the cold water off. Am I missing something???
canadaclub is offline   Reply With Quote
Old 12-21-2011, 05:59 AM   #2
DIY staff
Rewards Points: 7,174
Sorry--never saw one with one screw---
Looks like they had PEX on the tub spout---That can cause the shower head to dribble---
Old 12-21-2011, 06:01 AM   #3
Neither have I. Is it possible for you to take it back?
VIPlumber is offline   Reply With Quote
Old 12-21-2011, 06:53 AM   #4
Rewards Points: 582
looks like a defective mixer to me ....what do you other guys think,...take it back ..or at least ask to see another mixer and compare...??????
Old 12-21-2011, 08:31 AM   #5
I second Ben's suggestion.
Old 12-21-2011, 04:10 PM   #6
Handyman
Rewards Points: 512
I haven't heard of that before Why would that be?
Anyway, thanks all for the responses. I took the picture to the store and they recommended I send it to Aquabrass tech support. The store manager thinks it is defective also. I will let you know what transpires!
Dave
Old 12-21-2011, 04:14 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why does all of that matter?
It is a single handle valve. The cold is probably set to wide open and the hot is adjustable so that you can facilitate a "blend" and don't scald yourself. Does it work otherwise?
I guess I'm the one missing something.
XXX
Old 12-21-2011, 06:41 PM   #8
Handyman
Rewards Points: 512
unless the cartridge has to be changed. Question is..why put a screw shutoff only for hot supply?
Better question is, why do people purchase high end..triple price, non replaceable products when MOEN, or Delta sell similar products with lifetime warrantees?
Old 12-21-2011, 06:47 PM   #9
Rewards Points: 582
good point I have handled delta 30+ yrs great warranty program for dealers... almost forgot...DELTA WERE 1st BECAUSE WE LAST..
Old 12-21-2011, 08:11 PM   #10
DIY staff
The tub spout needs to be hard piped---the minor restriction caused by the PEX fittings is enough to cause water to back up into the shower head---common problem---use copper or threaded for the spout--
canadaclub (12-22-2011)
Old 12-22-2011, 04:04 PM   #11
Handyman
Rewards Points: 512
That's more like it! It was defective from the store.
Changed the spout connector too...thanks Mike
Old 12-22-2011, 04:09 PM   #12
DIY staff
Glad to see that pipe----that is common enough that I know about it (and PEX isn't used around here)
Pleased to help---Mike---
Old 12-22-2011, 10:14 PM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Sure makes more sense, I'll agree with that.
XXX
Old 12-22-2011, 10:18 PM   #14
Rewards Points: 582
that is a nice install... looks like mixer with 2-built in stops.......the way it suppose to look...glad to help... hey don't think iam being picky...is there teflon tape or pipe dope on male adapter for tub apout....???????
Old 12-23-2011, 06:09 AM   #15
Handyman
Rewards Points: 512
LOL,,,good eye Ben. Actually, its not installed yet, I just screwed it up to take the picture. Yes, there will be teflon on the joint.
Thanks again all
Well check valve problem, well question maxalex Plumbing 7 08-21-2016 02:21 AM
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
check valve question nsanto17 Plumbing 4 05-20-2011 08:04 AM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Replace a shower valve with no access panel ALfromSTL Plumbing 11 12-12-2008 08:56 AM
