-   -   aqua brass shower valve question (http://www.diychatroom.com/f7/aqua-brass-shower-valve-question-127264/)
canadaclub 12-21-2011 04:44 AM
1 Attachment(s)
This shower valve has only one shut-off screw (hot water) but the cold water side has a silver insert...not a screw (see pic) so I can't shut the cold water off. Am I missing something???
oh'mike 12-21-2011 05:59 AM
Sorry--never saw one with one screw---
Looks like they had PEX on the tub spout---That can cause the shower head to dribble---
VIPlumber 12-21-2011 06:01 AM
Neither have I. Is it possible for you to take it back?
ben's plumbing 12-21-2011 06:53 AM
looks like a defective mixer to me ....what do you other guys think,...take it back ..or at least ask to see another mixer and compare...??????
VIPlumber 12-21-2011 08:31 AM
I second Ben's suggestion.
canadaclub 12-21-2011 04:10 PM
I haven't heard of that before:eek: Why would that be?
Anyway, thanks all for the responses. I took the picture to the store and they recommended I send it to Aquabrass tech support. The store manager thinks it is defective also. I will let you know what transpires!
Dave
Bud Cline 12-21-2011 04:14 PM
Why does all of that matter?
It is a single handle valve. The cold is probably set to wide open and the hot is adjustable so that you can facilitate a "blend" and don't scald yourself. Does it work otherwise?
I guess I'm the one missing something.
canadaclub 12-21-2011 06:41 PM
unless the cartridge has to be changed. Question is..why put a screw shutoff only for hot supply?
Better question is, why do people purchase high end..triple price, non replaceable products when MOEN, or Delta sell similar products with lifetime warrantees?
ben's plumbing 12-21-2011 06:47 PM
good point I have handled delta 30+ yrs great warranty program for dealers...:thumbsup: almost forgot...DELTA WERE 1st BECAUSE WE LAST..
oh'mike 12-21-2011 08:11 PM
The tub spout needs to be hard piped---the minor restriction caused by the PEX fittings is enough to cause water to back up into the shower head---common problem---use copper or threaded for the spout--
canadaclub 12-22-2011 04:04 PM
1 Attachment(s)
That's more like it! It was defective from the store.
Changed the spout connector too...thanks Mike:thumbsup:
oh'mike 12-22-2011 04:09 PM
Glad to see that pipe----that is common enough that I know about it (and PEX isn't used around here)
Pleased to help---Mike---
Bud Cline 12-22-2011 10:14 PM
Sure makes more sense, I'll agree with that.
ben's plumbing 12-22-2011 10:18 PM
that is a nice install... looks like mixer with 2-built in stops.......the way it suppose to look...glad to help... hey don't think iam being picky...is there teflon tape or pipe dope on male adapter for tub apout....???????
canadaclub 12-23-2011 06:09 AM
LOL,,,good eye Ben. Actually, its not installed yet, I just screwed it up to take the picture. Yes, there will be teflon on the joint.:)
Thanks again all
