Apollo Fittings With Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-27-2012, 08:59 AM   #1
Apollo fittings with copper pipe
I'm using plastic Apollo fittings to join copper pipe. I have two questions:
1) What's the best way to connect a plastic Apollo tee to an existing line, since each connection has to bottom out in the fitting. I guess I can try to loosen some hangers to give enough play in the existing copper lines?
2) Because of the size of the Apollo fittings, I can't use the standard hangers. What is the best way to support pipe joined with Apollo fittings, particularly in areas where there are a lot of elbows? I'm finding that the whole thing is sagging, twisting, and rotating, and it's hard to continue work when things aren't straight.
Thanks!
CB55
Coolboy55 is offline   Reply With Quote
Old 07-27-2012, 10:02 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I'm not familiar with apollo fittings...... What is it?
Journeyman Plumber
Old 07-27-2012, 10:51 AM   #3
They are basically the same idea as Sharkbite fittings. They are plastic push-in fittings for use with PEX or copper, but because of their larger outer diameter, they do not allow the copper pipe to fit snug up against a surface, so I can't use the regular 1/2" copper pipe hangers.
Also, in congested areas with lots of elbows, I'm not sure what the best way is to secure the pipe so that it stays straight, since the self-weight tends to cause the pipes to rotate in the fittings.
Old 07-27-2012, 11:34 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 348
Maybe you should consider copper sweat or pex fittings and pipe
Sent from my iPhone using DIY Forum
Old 07-27-2012, 07:39 PM   #5
There must be a common way to support copper pipes that use push-in compression fittings...
Old 07-27-2012, 07:53 PM   #6
Plumber
Rewards Points: 348
There are more supports and fastening systems than you can imagine. But you'll only find the common ones in the local DIY store.
Try fabricating a spacer to fill the gap, then perhaps a common support will work
Old 07-27-2012, 09:14 PM   #7
Rewards Points: 616
try these called j hooks
http://www.homedepot.com/Plumbing-Pl...1#.UBM8r7QQuqs
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 07-27-2012, 09:51 PM   #8
Doing it myself
Alan's Avatar
It's really impossible to tell you how to support your pipe without some kind of picture of the area in question.
Journeyman Plumber
Compression Valve for leaky pipe (not copper)? DIYsoon2Bpro Plumbing 11 01-18-2012 07:40 PM
Why do they make copper plated steel pipe hangers? tractorfarmer Plumbing 0 01-15-2012 07:55 PM
Copper to Black Pipe Gas Connection dwolek HVAC 1 03-15-2010 06:02 PM
nicked copper pipe analogmusicman Plumbing 3 07-28-2008 09:54 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 11:55 AM
