Old 06-26-2010, 02:12 PM   #1
apartment washer on 4th floor
I bought washer and dryer for 4th floor apartment and was told I need a special hose for water pressure. Was told it requires a plumber. On fixed income and am wondering what exactly is needed and whether family can do the work?
jtrimble is offline   Reply With Quote
Old 06-26-2010, 04:30 PM   #2
Doing it myself
Alan's Avatar
You don't need a plumber for this.
You DO need high pressure hoses, as they will always be pressurized when the washing machine is off.
These are standard hoses, and they should come with your new washing machine. If for some reason it didn't come with them, go back to where you got the washer and ask for some.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
jtrimble (06-28-2010)
Old 06-26-2010, 08:46 PM   #3
If there are no spigots to attach the washing machine hoses to, building codes will probably require that you get a plumber to install some. (For multifamily buildings)
You can hook up just the cold washing machine hose to a non-adjustable sink spigot with screw on aerator by using an adapter in place of the aerator. Cap off the hot inlet for the machine. Leave the machine on the cold setting. Adjust the water temperature using the sink faucets, optionally you can set separate temperatures for wash and rinse manually by coming back at the right time in the cycle.
A swinging faucet spigot may leak at the pivot if you connect it to a washing machine this way.
Turn off the washing machine water when the machine is not in use regardlessof what kind of hookup you have.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 06-27-2010, 07:07 AM   #4
Maybe they were talking about the automatic shut off if a hose breaks.
You can buy them at any big box stores they have a valve in them if the hose breaks it shuts down the water so you don't flood out the house in this case the 3 floors under you.
COLDIRON is offline   Reply With Quote
Old 06-27-2010, 10:22 AM   #5
Super Moderator
Most towns in my area require a floor drain ---some require a drained pan under the machine.
Make sure your renters insurance covers a washer---Mike--
Old 06-27-2010, 10:47 AM   #6
Long-Time DIYer
Mike Swearingen's Avatar
Use stainless steel flex washing machine hoses, and either a pan with a drain through the wall or a floor drain or the auto shut-off device. One of the three will help prevent flooding the floors below.
As already advised, also turn off both the hot and cold spigots when not in use.
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-27-2010, 02:57 PM   #7
Not to discourage you from using a pan but from what I have seen when a hose breaks the pan is kind of useless as water goes all over the place. It might help depends upon the leak.
Old 06-28-2010, 03:26 AM   #8
Long-Time DIYer
I think that most local codes call for a floor drain above the first floor.
Need to check with local Building Inspection office. You probably need a permit and inspections for whatever you do anyway.
Use floor drain for washer ????? Russ Plumbing 2 01-31-2010 05:05 PM
Washer Drains..... Soap comes out of floor Drain?? choda_boy_04 Plumbing 2 01-21-2010 08:20 PM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 05:58 PM
Attaching 3/4 Sturdy Floor with PL 400 jamiedolan Flooring 1 09-04-2008 10:15 PM
Moving washer/ dryer from 1st to 2nd floor sebastien1 Remodeling 33 11-08-2006 10:31 AM
