AO Smith Water Heater Burner Wont Stay Lit. - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-11-2012, 07:16 PM   #16
DIY staff
Rewards Points: 7,174
Remove the two tubes coming out of the control valve---remove the screws holding the cover plate for the burner opening--then the whole burner assembly should slide out---
The manufacturer should have a set of drawings available on line--and a parts list.
Some makers will not sell to homeowners--only plumbers---my supply house carries repair parts for many brands--call and see if your plumbing supply house has parts for your brand---
Old 04-13-2012, 02:08 PM   #17
Residential Contractor
Hey Mikey! I might just have you over to my house. (You know where I live ) I have the EXACT same issue going on with the EXACT same heater.
I contacted AO and they told me the entire pilot assembly needs to be replaced, but the parts are available at Ace hardware.
The thing's only 4 years old. The assembly is around 40 bucks or so.
You can't replace just the thermocouple due to a fusible link that is built in.
rselectric1 is offline   Reply With Quote
The Following User Says Thank You to rselectric1 For This Useful Post:
ben's plumbing (04-13-2012)
Old 04-13-2012, 06:45 PM   #18
DIY staff
Get the parts--I'll do it for a hot beef sandwich and fries!
Call me---The whole guts just slide out after the cover plate is loosened.
AO Smith gas water heater - main burner won't stay lit ianshomeimp Appliances 3 05-31-2012 10:07 PM
No Hot water from A.O Smith GPSH/GPCR Gas Water Heater sghatty Plumbing 1 03-07-2012 07:23 PM
A.O. Smith water heater - cold water gma2rjc Plumbing 2 06-30-2011 10:16 AM
Pilot Light Won't Stay Lit on Water Heater jdolan HVAC 4 07-23-2010 04:42 PM
BradfordWhite Water Heater won't stay lit mwalla HVAC 3 03-02-2009 04:43 PM
