Old 04-08-2012, 08:35 PM   #1
AO Smith water heater burner wont stay lit.
It is a AO Smith promax GCV 40 100 water heater to be exact. I can get the pilot to light may take a second or two to keep it light but when I turn it to the on position and turn up the temperature the burner lights. It goes out along with the pilot light after a minute or two of heating. I do hear a slight "click" when it goes out. I have tried cleaning it to make sure its not starved for oxygen, didn't help. I checked to see if its under warranty and it is not. PLEASE HELP!
Fortypopper is offline   Reply With Quote
Old 04-08-2012, 08:45 PM   #2
Super Moderator
Is that a sealed unit (no door to the burners--clicker to light--little glass window)
or an open unit--(removable door light with a match)?
oh'mike is online now   Reply With Quote
Old 04-08-2012, 08:48 PM   #3
Yes, it is sealed. Glass window with clicker to light.
Old 04-08-2012, 09:37 PM   #4
Super Moderator
Call a plumbing supply house --you may not be able to buy the parts you need--usually only sold to licenced plumbers---either the thermo couple is dead or the flame sensor is defective---often the whole burner unit must be replaced---sorry---
Old 04-08-2012, 09:40 PM   #5
Super Moderator
AO smith has a technical help site and phone number---google that--my bookmarks aren't working tonight--
Old 04-08-2012, 09:41 PM   #6
Ok, thanks for replying I've posted a video to show what is actually happening.
http://www.youtube.com/watch?v=8eIww...p5LWQJopDsmOoQ
Old 04-08-2012, 09:54 PM   #7
Super Moderator
Sorry--computer is wacky tonight---no videos for me---Mike---
Old 04-08-2012, 10:00 PM   #8
Super Moderator
Come bail me out! One of the plumbesr here will jump in soon--I see Alan is on --there are some truely good plumbers here--one of them will be along soon---
Old 04-08-2012, 10:05 PM   #9
Thank you!
Old 04-08-2012, 10:39 PM   #10
seems like a weak thermocupler ..did not see in the video if there is a tempeture sensor for cloged vent....the thermocuppling could be changed...could pick up at local hardware...
ben's plumbing is online now   Reply With Quote
Old 04-08-2012, 10:47 PM   #11
Super Moderator
Ben--I don't know about A.O. Smith--but most of the sealed units I have delt with can not use a universal thermo couple---Must be original equipment---different threads---
Old 04-08-2012, 10:58 PM   #12
most tanks we deal with use univerisal ..except whirpool they have reverse threads....thanks for the info like you don't see any ao smiths....maybe someone else will chime in???
Old 04-08-2012, 11:04 PM   #13
Super Moderator
Good news on AO Smith--It was two Whirlpools that had me stopped---AO Smiths are better units and I have never needed to service one---
ben's plumbing (04-08-2012)
Old 04-08-2012, 11:29 PM   #14
Mike is right they cannot use universal thermo couples. Good news though I took out the whole assembly and scrubbed it down with a wire brush. Although it didn't look dirty...I re-installed it and its working fine now. Hope its not temporary. I thank you again for the time spent with me.
The Following 2 Users Say Thank You to Fortypopper For This Useful Post:
ben's plumbing (04-09-2012), oh'mike (04-11-2012)
Old 04-11-2012, 01:39 PM   #15
Question
I'm still fighting with my water tank. Going to try to bleed it first. Easter filled my days. If need be, how would I go about taking out the whole assembly, like Fortypopper mentioned?
Gerrie is offline   Reply With Quote
AO Smith gas water heater - main burner won't stay lit ianshomeimp Appliances 3 05-31-2012 11:07 PM
No Hot water from A.O Smith GPSH/GPCR Gas Water Heater sghatty Plumbing 1 03-07-2012 08:23 PM
A.O. Smith water heater - cold water gma2rjc Plumbing 2 06-30-2011 11:16 AM
Pilot Light Won't Stay Lit on Water Heater jdolan HVAC 4 07-23-2010 05:42 PM
BradfordWhite Water Heater won't stay lit mwalla HVAC 3 03-02-2009 05:43 PM
